Fiesta-Si.com • View topic - What brakes do you have? (excluding standard Si brakes)
It is currently Fri Mar 06, 2026 11:54 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 12, 2007 12:47 pm
PostPosted: Mon Mar 12, 2007 12:51 pm
Yes!
Thanks 8-)
Zetec Mapping Services
PostPosted: Mon Mar 12, 2007 4:30 pm
PostPosted: Mon Mar 12, 2007 11:44 pm
Here is another pic of the ST150 setup behind 15's
PostPosted: Tue Mar 13, 2007 12:01 am
PostPosted: Tue Mar 13, 2007 1:00 am
I'm running 15" steelies.. 4x4 cossie calipers fit with bags of room.. I have sorted out a set of ST150 brakes which I should be getting on Wednesday, so i'll soon find out!
8-)
PostPosted: Tue Mar 13, 2007 1:05 pm
PostPosted: Tue Mar 13, 2007 2:07 pm
PostPosted: Tue Mar 13, 2007 2:10 pm
PostPosted: Wed Mar 14, 2007 10:52 am
i can see your point dude.
PostPosted: Thu Mar 15, 2007 12:37 am
PostPosted: Thu Mar 15, 2007 4:15 am
i might sort some spacers out for mine then see if i notice any difference.
I had somewhere (ft.com i think) of someone using a different disk to get rid of that offset issue
PostPosted: Sat Mar 17, 2007 9:50 pm
PostPosted: Sat Apr 14, 2007 1:54 am
how come no one uses escort rs turbo breaks?
ive got a set including discs and calipers on its way to me for £20,
i did i fuck up selling my si ones thinking the rs stuff was better?
nothing beats stella like stella beats your wife
PostPosted: Sun Apr 15, 2007 4:28 pm
If your talking about Fiesta RS ones, then they are exactly the same as the Si brakes anyway mate.
A bit late to this post, but i used to have 4x4 cossie discs and calipers and they needed spacing around 5mm. Then i swapped to st150 discs (EXACTLY the same size) and the calipers didnt need spacing.
PostPosted: Sun Apr 15, 2007 5:13 pm
was it just the discs you changed?????
PostPosted: Sun Apr 15, 2007 5:14 pm
Most Ford calipers have a constant offset.. the offset is typically changed with the disc.. so it's quite likely that a 4x4 cossie caliper will work with a ST150 disc!
PostPosted: Sun Apr 15, 2007 5:24 pm
Yes and Yes
 Post subject: Brakes
PostPosted: Wed Apr 18, 2007 7:12 pm
I have RS2000 front discs, pads & calipers & XR4x4 rear discs, calipers & pads.
Users browsing this forum: Google [Bot] and 25 guests
