Fiesta-Si.com • View topic - Zetec turbo
It is currently Sun Mar 08, 2026 10:47 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Zetec turbo
PostPosted: Tue Nov 30, 2010 9:39 pm
i think my T34 was a bit OTT :lol:
PostPosted: Tue Nov 30, 2010 11:52 pm
So even with a t34 can you get away with only different pistons?
PostPosted: Wed Dec 01, 2010 12:07 pm
yeah,if i was spec'ing mine again for a pretty solid budget build id go for..
C20LET pistons with Standard Rods and ARP Rod bolts
Standard head and Cams
Modified Block for the breather etc
ERST Exhaust Manifold
T34
FRST Inlet using an adapter plate
Suitable sized injectors ( speak to ian howell from area six )
PostPosted: Wed Dec 01, 2010 12:52 pm
Still not sure whether to keep the OFAB gear off of my FRST when I break it in case I fancy doing something like this in the future or just sell it on when I start to break it
Some good information here though
Scott
PostPosted: Wed Dec 01, 2010 1:22 pm
if your planning on doing something like this in the future scott i'd keep it, as i had an issue getting a full ofab loom and ecu with all the sensors!
its a cheap affective way to get you on the road if you dont want to fork out for aftermarket management!
PostPosted: Wed Dec 01, 2010 2:46 pm
PostPosted: Wed Dec 01, 2010 2:48 pm
could i get away with my rs1800 inlet and 2.0 throttle body?
Or does it have to be FRST
Also, doesnt a FRST exhaust manifold fit the zetec, or would you use the ERST manifold for the bigger turbo.
PostPosted: Wed Dec 01, 2010 3:09 pm
PostPosted: Wed Dec 01, 2010 3:33 pm
yeah, i heard that nissan 200sx injectors work on the rs1800 fuel rail.
Does the ERST manifold bolt straight on or does that need an adaptor plate too?
PostPosted: Wed Dec 01, 2010 3:35 pm
iirc it all lines up correctly but a few of the bolts need to be re drilled and tapped
PostPosted: Wed Dec 01, 2010 3:56 pm
thanks for the info guys :D
Just gunna have a look on prices for an ERST turbo
As i know FRST turbos with manifold and oil pipes range from £50-£150
PostPosted: Wed Dec 01, 2010 4:40 pm
