Fiesta-Si.com • View topic - RS2000 rear beam setup
It is currently Sat Mar 07, 2026 11:52 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 31, 2010 9:00 pm
paul wouldnt even drill it, just attach with some tigerseal, lol
PostPosted: Wed Mar 31, 2010 9:12 pm
granted i may have jokingly called him pikey parker in the past..i know he wouldnt do something that dangerous lol
the calls i used to get about the pickup fucking about tho....i dont miss that piece of shit one single tiny bit!!!
PostPosted: Wed Mar 31, 2010 10:00 pm
PostPosted: Fri Apr 02, 2010 12:52 am
focus and focus st170 rear discs work on mk4/5 beam i believe.
PostPosted: Fri Apr 02, 2010 8:12 pm
Yeah that's right i remember reading on that one... i think it was the ZS beam.
However if the ST brakes fit on a 3.5 beam that would be immence! However is it true?
PostPosted: Fri Apr 02, 2010 11:12 pm
dont think so mate.
PostPosted: Sat Apr 03, 2010 9:44 am
FIESTA ST REARS FIT.
PostPosted: Sat Apr 03, 2010 7:55 pm
Really?
PostPosted: Sat Apr 03, 2010 11:40 pm
PostPosted: Sun Apr 04, 2010 2:13 pm
My hubs are fucked and I need to upgrade my brakes anyway....
Is it worth getting the RS2000 setup, messing about with this Zetec-S stuff, or staying standard?
In the process of murdering my second Si :'(
PostPosted: Sun Apr 04, 2010 2:26 pm
To be honest.
I would just sort the drums out... Upgrade your front brakes. The rear drums are good enough for road use.
unless you can get everything you need to do discs.
PostPosted: Sun Apr 04, 2010 5:58 pm
Ah right cool, I've gotta upgrade suspension and sort the hubs out so didn't know if it was worth doing or not while I had it all apart....saves me some work so I'm happy...
PostPosted: Sun Apr 04, 2010 7:36 pm
So basically, fiesta ST rear disks fit the mk3.5? without modification?
That would be a dream come true as i am getting a ST setup on the front
PostPosted: Mon Apr 05, 2010 9:28 am
PostPosted: Mon Apr 05, 2010 12:15 pm
anything is possible guys its all about setting your mind and skills to it. with the right brackets and hubs you can fit just about any setup to the rear. but a good balance IS essential else it will just pirouete down the road when you have to pull up in a hurry.
Jam.
PostPosted: Wed Apr 14, 2010 1:57 pm
PostPosted: Sun Apr 18, 2010 10:44 am
Sorry to hijack it a bit.....
I managed to source the RS2000 front and rear setup for a good price....so will hopefully be going ahead with it....now what's this business with the flexis, do I need to get some sort of custom ones, or will I need RS2000 ones or something? Planning on going for braided hoses anyway......
Cheers for any help :)
PostPosted: Sun Apr 18, 2010 2:49 pm
front or rear hoses?
PostPosted: Sun Apr 18, 2010 7:01 pm
Will be doing both, as far as I know the Si front ones fit the RS2k calipers but the rear ones are different?
PostPosted: Sun Apr 18, 2010 8:15 pm
rears are drastically different. youll have to have them made to measure. run the flexi under the beam and P clip it to that.( i think it has to be secured every 30cm for MOT regs..im pretty sure it has to) then upto the brake pipe..with enough slack to allow it to move without wrecking anything.
the fiesta centre ones will be too long as they use sierra calipers mounted in a different position
HTH
Jam.
Users browsing this forum: Google [Bot] and 12 guests
