Fiesta-Si.com • View topic - An Rs Turbo in an Si
It is currently Tue Mar 10, 2026 2:28 pm
Post new topic Reply to topic  [ 49 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: An Rs Turbo in an Si
PostPosted: Tue Oct 21, 2008 2:50 pm
Yeah he had a T3, just no derv box :lol:
PostPosted: Tue Oct 21, 2008 3:03 pm
:lol: fair enough
We'll see ;)
PostPosted: Tue Oct 21, 2008 3:04 pm
but a standard escort rs turbo should do 42mpg at 56mph in 5th when standard 8-)
PostPosted: Tue Oct 21, 2008 5:02 pm
PostPosted: Tue Oct 21, 2008 6:55 pm
Yep, this should go into classic FSI threads!
PostPosted: Thu Oct 23, 2008 8:22 pm
PostPosted: Sun Oct 26, 2008 6:16 pm
ok well it appears im getting slated for that idea, was basically just looking for a cheap alternative, but can you turbo a rs 1800 or would a silver top 2.0l be better ?
PostPosted: Sun Oct 26, 2008 6:19 pm
dont feel slated mate, do what YOU want to do ;)
you can turbo the 1.8 or the 2.0ltr.
either decomp plate and risk it popping or doing it properly will be expensive either way.
if you want turbo and can get the rs gear then go for it, i would :chill:
PostPosted: Sun Oct 26, 2008 6:21 pm
well just wanted to give people a run for there money, got all the aggresive styling but its prob only running 115bhp if im lucky :( so what would you do if you was me ? and na i dont feel slated i just feel stupid for asking it when i knew a 2l is more efficient and easyier to get hold of :doh:
PostPosted: Sun Oct 26, 2008 6:32 pm
My options would be:
RS1800 engine, as they still produce good enough power... and they go straight in.
2.0ltr zetec, produce slightly more torque and a few more bhp but need to change a few easy bits to fit in
RST 1.6 CVH Turbo engine, good if you can source all the correct bits easy enough and the engine isnt shagged :)
Go balls out Zetec Turbo, but will cost a fair few grand
Go balls out N/A zetec, will cost a fair bit also
or if your looking into something daft... and dont mind the cost/hassle you could fit anything. st170 engine, focus rs setup etc
PostPosted: Mon Oct 27, 2008 9:28 am
PostPosted: Thu Oct 30, 2008 1:57 pm
the main problem is i am 18 and Mr insurance likes to rape me constantly so nothing overly stupid, ive heard correct me if im wrong but you can turbo a 1.6 zetec ?? this would prob be the best option as i have basically all the over main bits for my zetec.
PostPosted: Thu Oct 30, 2008 5:08 pm
You can, but it will probably see around 130bhp.... so you might as well go 1.8 or 2.0ltr for 50 quid :)
PostPosted: Fri Oct 31, 2008 1:03 am
50 quid thats all it would cost me and can you turbo a 1.8 ?
PostPosted: Fri Oct 31, 2008 1:12 am
PostPosted: Fri Oct 31, 2008 6:21 pm
how much would it cost roughly to turbo a 2l zetect ?
PostPosted: Fri Oct 31, 2008 6:25 pm
on an extreme budget you migth get away with doing it for 1-2k
decomp plate, erst exhaust manifold, erst T3, frst exahaust, some for of IC, frst OFAB/OFAC management/megaqsquirt, injectors, boost pipes and a few other bits
not to forget getting your block modified for breathers and your sumo modified for an oil return
PostPosted: Fri Oct 31, 2008 6:26 pm
PostPosted: Mon Nov 03, 2008 12:38 am
from doing alot of reading on engine building etc ive decided to do the ZVH build i will use a 1.8 zetec bottom so i think that will be more than adiquite especially running the RST turbo, with the right mods it should hopefully be running a 230+ bhp, will let you guys know how it goes but wont be doing nothing till i get some money.
PostPosted: Mon Nov 03, 2008 1:35 am
Zetec Turbo will be alot easier than doing the ZVH, and will cost around the same ;)
Users browsing this forum: Google [Bot] and 18 guests
