Fiesta-Si.com • View topic - 10pm lots of stuff for sale 29/dec/2012 more to add...
It is currently Fri Mar 06, 2026 10:16 am
PostPosted: Sat Dec 29, 2012 12:00 am
zetec exhaust manifold £25
egr if i remember rightly? £2
mk3 mk3.5 abs brake system pumps and belts. £5
new (old stock) fiesta mk3 mk3.5 wishbones. not pair one i persume is power steering one is manual?
£10 each
pair of mk3.5 mk3 powersteering wishbones bushes dead so ok for polly bush? (done about 400miles) £2
mk3.5 zetec 1.6si alternator worked great! £20
brand new fag lighter and set up £5
clocks with glass seperated £1
1.1 +1.3? fiesta fan £2
fiesta mk3 mk3.5 window rubber £2
mk3.5 fiesta si shocks no springs (untested but persume ok) set £15
fiesta si 1600 long starter motor worked on my car (too long to go with my ashley manifold so i changed) £5
k&n induction pipe £5
ford fiesta si front arch splats pair £10
si power steering auxilary pully idler (400 miles) £5
modifyed and sprayed exhaust manifold cover (top lugs removed so not in way of induction pipe) £3
standard ht leads off 1600 zetec £10
si battery tray to airbox brackets
si air intake cross over pipe
si air box
si airbox intake
si airbox to rocker breather
odds and sods and (the well i hope you can 'identifys'):
hcs rocker cover and rockers 1.1? 1.3? mk1? mk2? mk3?
odds i know the long bracket is off a mk3 si 1600 brake servo to steering rack bracket
inlet? hcs? 1.1? 1.3?
hcs 1.1 1.3 alternator
coil 1.1 1.3 hcs??
dizzy off hcs?
mechanical fuel pump off something>
oil pump.... hcs??
apparently a escort powersteering type auxilarybelt tentionor (was ordered by mistake for my si) new £60
some door rubber not sure what off!?
some door rubber not sure what off?!
Wire with eylets either end? not sure what off? brakes? new £2
engine lifting eys rs...
cheers sam
#0781 366 9260 call between 9am and 10pm
TEAM AUBERGINE
PostPosted: Sat Dec 29, 2012 10:46 pm
the 6th nd 7th pic up from the bottom is a mechanical fuel pump
PostPosted: Sun Dec 30, 2012 9:15 am
TEAM AUBERGINE
