Fiesta-Si.com • View topic - my fiesta parts for sale loads cheap updated
It is currently Fri Mar 06, 2026 7:25 am
Post new topic Reply to topic  [ 67 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Tue Jul 31, 2012 4:57 pm
hi everyone got all these parts for sale as i want.to clear the garage out completely, im more than willing to sort out deals on parts for bulk buys collection is fine and im located in chelmsford essex and my mobile.number is 07926872886 message me post up or call or text me i can post most items but as some parts are very cheap the postage.may cost more than the item itself, i cannot post overseas and will not post airbags
car jacks fiesta mk3 1quid each got 4 available
centre consol in black
petrol flap mk3.5 1 quid
xr2i rear bumper £free
si fog lights and surrounds £15
zetec rear exhaust bracket bolts to axle reserved ben
si 1.4 rear head rests ideal for rear headrest conversion 10quid the pair reserved meilack
roof rack gutter trims 1 quid each
rear wiper motor 3quid
central locking module 2quid
brake light and handbrake switches 1quid each
washer bottle motors 1quid each
non pats light digital clock 3quid
zetec water pump pulleys 4 quid each
door pull surrounds 50p each
switches front fog switches and electric window switches 3quid each, all others 1quid each
parcel shelf supports 5quid for both
fuel filler neck 10quid from a si mk3.51994
fan motor from si 1.6 2quid
dash vents 50p each
throttle pedal sold
all items in pic 50p each
indiactor stalks mk3.5 5quid
mk3.5 fiesta interior base plates 4quid the pair
mk3 fiesta interior.base plate passenger side 2quid
fiesta gearknob 1 quid
water pump zetec mk3 pulleys 3quid each
grab hands 1quid the pair early.spec and late spec ones available
coolant bottle 1quid
rear lights 2quid the pair
drivers side mirror for early mk3 fiesta rs turbo/rs1800 5quid
fiesta si steering wheel (smaller than standard 3.5 steering wheel) with airbag if needed will not post airbag 8quid
pats transponder from 94 si 2quid
ka/fiesta mk4/mk5 efi 1.3 idle control valve brand new 5 quid
fuse box with all relays and fuses from 1994 fiesta si 1.6 16v 5quid
wiper motor and linkage 5quid
front wiper motor 2 quid
rev counter speedo dials from a xr2i 16v 8 quid
zetec coil pack 5 quid
front anti roll bar bracket 1quid
clutch fork 1quid
ford fiesta mk3 headlights reserved ben
heater blower motor 5quid
bulb holders for the rear 50p each
front indiactor lense gen ford 3quid
horns 1quid each
window winders 1quid each
2.0 zetec crank seal and other seals 4 quid the lot
1.1/1.3 water pump with gasket brand new 5quid
1.3 spi inlet to spi unit gasket brand new 2quid
mk3 digital clock 2quid
manual steering column for mk3 fiesta 10quid
fiesta si power steering rack gaiters 4quid the pair brand new
red front suspension tops 4quid
stonger boot strut.from early mk3 5 quid
5 door central locking.motors 1 left £2
abs driveshaft long one left only, 5quid
bonnet cable, speedo cable, 1 quid each
manual steering racks 5quid each
mk3 zetec cat converter 10quid
blacktop cam cover 5quid
5 door front electric window.motors 1 available now
power steering set up whole lot in pic reserved
seat sides mk3.5 fiesta free
offside 3door cebtral locking.motor 2 quid
start motor and alternator looms zetec mk3 5quid for both
amp is perfect working order has built in fan 2 channel 15quid
mk3.5 b pillar 2 quid
Last edited by fiestasiphil on Sat Nov 10, 2012 10:36 pm, edited 27 times in total.
PostPosted: Tue Jul 31, 2012 6:34 pm
Ill take the early mk3 b pillar covers at ford fair mate :)
PostPosted: Tue Jul 31, 2012 6:45 pm
ok mate no trouble are u on the si stand? i will be updating the whole thread late tonight with another 50 items or so and have a new contact number so will have it all up then :)
PostPosted: Tue Jul 31, 2012 8:12 pm
i am indeed mate, same as last year but i will be in my mk5 daily ha, sur ill wait and see if theres any other bits i fancy when you update and ill let you know :thumbsup:
CheeRS
PostPosted: Wed Aug 01, 2012 1:12 pm
Hello mate, ill take 2 of the raer antiroll bar brackets with the extra square bit on them
PostPosted: Wed Aug 01, 2012 3:20 pm
PostPosted: Wed Aug 01, 2012 5:12 pm
maf sensor
cam cover
fuel pump
1 rear wiper motor
passenger door pocket
fog light
gear sticker gaiter sold!!!!!!
PostPosted: Wed Aug 01, 2012 7:44 pm
Hi Phil,
Will take the guru Ecu
Smoked side repeaters
3mm wheel spacers
Will be on the Si stand at ff next week too!!
PostPosted: Wed Aug 01, 2012 11:04 pm
2 rear arb brackets,k&n breather, locking wheel nuts, power boost valve and smoke side indiactors sold
PostPosted: Wed Aug 01, 2012 11:06 pm
PostPosted: Thu Aug 02, 2012 4:33 pm
Hi mate, if you've still got them i want;
The de-cat,
Powerflex exhaust rubbers,
and 3mm wheel spaces if they ain't sold?
I can meet you as i live Colchester so no need for postage.
Thanks.
'It's not a car, it's a daily project..'
PostPosted: Thu Aug 02, 2012 4:53 pm
im totally up for the mk3 steering coloum covers, top and bottom.
someones tried to steal my car at some point and ripped mine off,
you coming ford fair,
buttery biscuit boost
PostPosted: Thu Aug 02, 2012 10:23 pm
Interested in a few bits if I can arrange a way to collect them.
PM sent.
PostPosted: Fri Aug 03, 2012 7:54 am
PostPosted: Fri Aug 03, 2012 8:00 am
PostPosted: Sat Aug 04, 2012 10:46 am
PostPosted: Fri Aug 17, 2012 4:11 pm
I'll. Take those 2 remainig rear anti roll bar d brackets mate,
PostPosted: Fri Aug 17, 2012 4:53 pm
PostPosted: Fri Aug 17, 2012 5:04 pm
bugger,
The fez failed its mot on those, and they are no longer available
PostPosted: Fri Aug 17, 2012 5:16 pm
