Fiesta-Si.com • View topic - aftermarket ecu
It is currently Fri Mar 13, 2026 7:06 am
 Post subject: aftermarket ecu
PostPosted: Sat Apr 14, 2007 11:03 pm
does any one know where i can get an aftermarket ecu ? iv been looking at emerald ecu's but if any one has any info on aftermarket ecu's like names and what there like it would be most appreciated
i also have a laptop with maga jolt v2 on it that i can plug in to the car (ecu well for most aftermarket ones) so if the ecu comes with a program i could load it to the laptop and mess around with it he he he
PostPosted: Sat Apr 14, 2007 11:56 pm
what about megasquirt?
DTA, omex etc are good too :P
PostPosted: Sun Apr 15, 2007 12:55 am
http://www.megatuned.com :)
Zetec Mapping Services
PostPosted: Sun Apr 15, 2007 6:07 pm
i thought mega squirt was just for fuel or is it ?
saqmaster;-
iv had a looky at your site so what do you recomend ;) and how long would it take to set up lol
PostPosted: Sun Apr 15, 2007 6:08 pm
Nope, Megasquirt does it all... what's the spec. you need an aftermarket ECU for?
PostPosted: Sun Apr 15, 2007 6:19 pm
erm newman fast road cams (not set up properly yet hehe)
ported inlet manifold (1.8), to the head and sandwich plate,
casts ground off from inlet manifold and head ports,
lightened and balanced fly wheel (1.6 si) ,
crank polished and balanced,
k&n 57i induction kit,
de-cat,
bb2 i think exhaust de-cat back lol
oh and the 2.0l, ecu throttle body and air flow meter,
im sure there some thing else but i cant remember
PostPosted: Sun Apr 15, 2007 6:21 pm
Probably not worth the cost to be honest fella.. the current map in your 2 litre ECU won't be too far wrong for what you've got there!
PostPosted: Sun Apr 15, 2007 6:23 pm
ar reet doh! lol cheers any way looks like iv got a hard task trying to set the cams up properly then and sort out any other problems that crop up
PostPosted: Sun Apr 15, 2007 6:24 pm
Do Newman give you Lift@TDC figures, like Kent do?
PostPosted: Sun Apr 15, 2007 9:51 pm
they give the lift and that but not the what i call timing bit like 10 or 8 degrees witch is poo unless im reading it wrong, but iv been searching for a fue days now so i might just fax them at work and see what i get
this is what iv got so far for--
FORD ZETEC PH2 CAM
forz/260/400
full lift
IN. ATDC EX. BTDC
110 110
IN OPEN EX CLOSED
18-58 58-18
PostPosted: Sun Apr 15, 2007 9:52 pm
Ask them for lift@tdc figures.. easiest to time in..
PostPosted: Sun Apr 15, 2007 9:59 pm
OOPS must of pressed submit before i should of lol ass on my above post
