Fiesta-Si.com • View topic - xr kit and spraying.. not sure..
It is currently Fri Mar 13, 2026 7:11 am
PostPosted: Mon Mar 19, 2007 1:31 am
Righty-ho
Another one of my stupid questions again..
As you might have seen the pictures of my car and bits of the rear arch is covered in primer due to attacking rust yonks ago and also a new wing still in black has been fitted..
Now I want to fit the xr skirts and arches to the 5 door..
SO
Do I, spray the kit, stick it to the car and all that modding to the back door bit.. and leave the black wing and the primer, and then when it gets fully resprayed, it will get sprayed with the kit already on it..
OR
Do I get the car sprayed up, then fit the kit.. ?!
Bearing in mind I might want to smooth it into the arches, not sure yet tho
Cheers
PostPosted: Mon Mar 19, 2007 1:47 am
i think you'd achieve best results if you got the kit fitted with your car being sprayed at the same time.
thats what i'd do, unless you wanted them kit on desperately in which case i'd do the 1st option
probably not much help
cheers
andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Mon Mar 19, 2007 12:45 pm
i agree with fitting it before the sprayjob is done.. will all have the same color coat then
if your really bothered about it id get a couple of tins and spray it up though just to blend a little bit :)
PostPosted: Mon Mar 19, 2007 1:39 pm
spray the kit at the same time as car, but dont spray it fitted
PostPosted: Mon Mar 19, 2007 1:42 pm
PostPosted: Tue Mar 20, 2007 2:27 am
Is it a good idea to smooth the arches into the bodywork?
Is the possibility of them cracking high?
PostPosted: Tue Mar 20, 2007 9:17 am
as long as its done with some of that flexy filler (tay might know what im onabout)
you should be fine
PostPosted: Tue Mar 20, 2007 10:28 am
chances of them cracking is very high!
i wouldnt bother
PostPosted: Tue Mar 20, 2007 11:39 am
