Fiesta-Si.com • View topic - cleaning k&n filter
It is currently Fri Mar 13, 2026 3:57 am
 Post subject: cleaning k&n filter
PostPosted: Fri Feb 16, 2007 7:34 pm
PostPosted: Fri Feb 16, 2007 7:45 pm
PostPosted: Fri Feb 16, 2007 7:57 pm
PostPosted: Fri Feb 16, 2007 8:15 pm
PostPosted: Fri Feb 16, 2007 8:18 pm
PostPosted: Fri Feb 16, 2007 8:21 pm
PostPosted: Fri Feb 16, 2007 11:24 pm
proper kit is the best
we use this a lot on me bruv's speedway bike's KN filter
dont over oil it when its dry tho
PostPosted: Sun Feb 18, 2007 1:15 pm
Proper cleaning kit is the best. I done mine the other day actually. Rinse the filter first and shake off any loose dirt that's on it. I use an old toothbrush to get all the crap dislodged. Rinse again. Then apply the cleaning solution and let it soak for a bit. Rinse again and let it dry out. Apply the oil and away you go :)
PostPosted: Sun Feb 18, 2007 6:47 pm
Would the stuff work on a non k&n filter with the same sorta material, got an apiro heatshield filter on mine and the gfs car and it looks to be the same stuff the k&ns are made of
PostPosted: Sun Feb 18, 2007 8:25 pm
PostPosted: Sun Feb 18, 2007 9:01 pm
PostPosted: Sun Feb 18, 2007 9:10 pm
PostPosted: Mon Feb 19, 2007 11:20 am
Dont over do it with the oil though.
can cause MAF sensor issues
