Fiesta-Si.com • View topic - Suspension brands
It is currently Fri Mar 13, 2026 3:57 am
 Post subject: Suspension brands
PostPosted: Fri Feb 09, 2007 2:32 pm
What suspensions brands are any good, looking at upto £400 for a shocker and spring set! Are there any out there that you guys would recomend, not gmax tho they're terrible as they rattle their asses off!
Cheers
Scoobs are for chavs
PostPosted: Fri Feb 09, 2007 2:35 pm
gaz, koni, spax, elbiach, etc etc
there all good.. you just pay for what you get
PostPosted: Fri Feb 09, 2007 2:42 pm
Mark don't be a prat, if your gona spend that much spend i little extra and get coilovers, your car will handle fantastic with them mate!
You know you want to! :)
PostPosted: Fri Feb 09, 2007 2:45 pm
PostPosted: Fri Feb 09, 2007 2:51 pm
PostPosted: Fri Feb 09, 2007 2:57 pm
PostPosted: Fri Feb 09, 2007 3:16 pm
PostPosted: Fri Feb 09, 2007 4:50 pm
PostPosted: Fri Feb 09, 2007 9:00 pm
£337 delivered for a Weitec HICON GTN Coilover Kit! :P 8-)
http://www.europerformance.co.uk/pages/ ... ?id=328941
and for future reference use
PostPosted: Fri Feb 09, 2007 9:43 pm
Get Spax or Koni adjustables. Coilovers are overkill for the road. You'll need to have them set up properly to get the full benefit and you say you're pushing the boat out as it is! :) Damping adjustment is ideal for the road.
PostPosted: Sat Feb 10, 2007 6:30 pm
I've had no problems with the gmax on mine.
But i'd go for something a little more 'upmarket'
like spax, heard they are good ;)
PostPosted: Sat Feb 10, 2007 7:47 pm
PostPosted: Sat Feb 10, 2007 11:59 pm
Coilovers wouldnt waste my money on anything else !
ive got gmax at the moment there not as bad as everyone makes them out to be just a good cheap alternative !!
PostPosted: Sun Feb 11, 2007 2:26 pm
PostPosted: Sun Feb 11, 2007 5:48 pm
does it matter if i lower the rear and not the front or do both have to be done?
Breaking Standard Si
PostPosted: Sun Feb 11, 2007 6:40 pm
PostPosted: Sun Feb 11, 2007 7:21 pm
PostPosted: Tue Feb 13, 2007 12:33 am
PostPosted: Tue Feb 13, 2007 2:11 pm
PostPosted: Tue Feb 13, 2007 7:36 pm
the main reason i'm going for coilovers is that i want the car to sit level from a side on view and if i can i want to go lower than 60mm say 70mm- 75mm :)
