Fiesta-Si.com • View topic - cossie brake question?
It is currently Thu Mar 12, 2026 11:52 am
 Post subject: cossie brake question?
PostPosted: Mon Jun 26, 2006 2:15 am
when doing said brake conversion, what carriers are used with the calipers? fezzy ones or the escort ones ?any help is apprieciated
PostPosted: Mon Jun 26, 2006 8:36 am
escort 4x4 ones. you'll probably need 3 washers per bolt to space it out aswell
PostPosted: Mon Jun 26, 2006 3:23 pm
as JD said but the washers may vary as i've got either 4 or 5 per bolt on mine
PostPosted: Mon Jun 26, 2006 7:11 pm
thanks guys it was keeping me up late
PostPosted: Tue Jun 27, 2006 12:49 am
Could someone tell me what i need for this conversion as i wanna get it done sometime 8-)
PostPosted: Tue Jun 27, 2006 11:54 am
as far as i can gather, cossie 4x4 front calipers,carriers,discs,and pads, the fiesta brake hoses fit.
but u will need longer bolts and some washers to space the carriers correctly, am i right?
please tell me as i'm supposed to be doing this next week
PostPosted: Tue Jun 27, 2006 12:26 pm
yep thats about right i think it's either escort 4x4 or sierra 2wd ones fit. but you need the complete brake assemberly you can't swap parts over. the pipes still work but it is recommended that you get braided hoses.
PostPosted: Tue Jun 27, 2006 12:42 pm
how much roughly do them parts cost?
PostPosted: Tue Jun 27, 2006 12:45 pm
the 2wd ones are 4 pots and dont fit apparently, is it worth getting grooved discs and decent pads or will it lock up if breath near the pedal
PostPosted: Tue Jun 27, 2006 12:59 pm
Don't forget the ST150 setup, which is pretty much the same size/power but with no spacing needed
PostPosted: Tue Jun 27, 2006 4:45 pm
yep it's sierra sapp 4x4 or escort ones
PostPosted: Tue Jun 27, 2006 9:26 pm
Ive got these on mine. They are brilliant.
As said you need the 4x4 calipers, carriers, discs and pads. They fiesta brake hoses will fit the cossie calipers. You will also need four M10 bolts, around 30mm long and they MUST be high tensile, grade 10 or above. Dont buy some loose ones from Halfords or a motor factors as these will nearly always be grade 8.8. The amount of spacing required varies, typically around 4-5mm. Washers can be used but its not recommended because they tend to have burred edges which means they dont sit completley flat. Its best to have some spacers machined. HTH people :)
Or as said use ST150 ones and save some work
PostPosted: Tue Jun 27, 2006 9:31 pm
Cost?
PostPosted: Tue Jun 27, 2006 9:36 pm
Oh yea. I paid £46 for mine complete with discs and pads of ebay, but i have an eye for a bargain :lol: Expect to pay around £60 though ive seen them go for over £120 :o
PostPosted: Tue Jun 27, 2006 9:45 pm
Ah thats not too bad then :)
PostPosted: Wed Jun 28, 2006 4:17 am
just bought a set of calipers off ebay for £40, then getting disks off a mate for under trade price as he has them hanging around, and then pads at trade price. Dunno what theyd be normal price, dread to think!
PostPosted: Wed Jun 28, 2006 9:29 am
has anyone tried the focus st170 setup on a fiesta?
and whats it like
