Fiesta-Si.com • View topic - Need advice ASAP please
It is currently Tue Mar 10, 2026 7:45 pm
 Post subject: Need advice ASAP please
PostPosted: Thu Nov 17, 2011 12:21 am
Been offered puma 1.7 engine cheap now the tricky part will it fit in mk5 fiesta 51 plate 1.3 cvh engine bay I know gearbox an ecu will need changing as well as brakes and ecu anything else I need to think about
PostPosted: Thu Nov 17, 2011 12:39 am
full wiring loom, all the mounts, uprated suspension, bigger brakes, driveshafts, maybe different hubs, exhaust system, manifolds etc, full tank with uprated fuel pump.
where are you located matey?? as i would like to say if you think thats too much i maybe interested if its cheap as you say it is
PostPosted: Thu Nov 17, 2011 12:43 am
Yeah know all suspension brakes etc etc was more the wiring and ecu wasn't 100% on the work itself ain't a problem just debating wether it's worth doin cause got some other plans lined up for after xmass
PostPosted: Thu Nov 17, 2011 12:51 am
its worth doing if you has a zetec s as it all pretty much plugs and play! as where with a 1.3 theres not much you can do, unless you know a crashed up a zetec s you can use donor parts etc
PostPosted: Thu Nov 17, 2011 12:57 am
Gonna give it a miss an do what I originally planed pm,d you
PostPosted: Thu Nov 17, 2011 1:13 am
nice one matey!!
PostPosted: Thu Nov 17, 2011 1:21 am
No worrys lol let me know if you take a chance on it
PostPosted: Thu Nov 17, 2011 11:16 am
u wont need to swap the tank over
engine loom ecu key mounts gearbox and drive shafts and exhaust
its worth doing but u dont have todo suspension and brakes at the same time
what u will have to look out for if the car has a digital dash or analouge one as u want to get one the same as your car
its still and easier conversion than a 2ltr zetec
