Fiesta-Si.com • View topic - best rpm for launching
It is currently Tue Mar 10, 2026 10:57 pm
 Post subject: best rpm for launching
PostPosted: Mon Aug 01, 2011 1:58 am
What's the best rev to hold when doing a hard launch?
I ask not to be q hooligan, but so I can do my best at Ford fair on the 60 strip :)
I've noticed 3-3.5 works but still get wheel spin
PostPosted: Mon Aug 01, 2011 8:10 am
Remember for the best times, knock your front tyres down below 20psi (say 15psi?) and also remember to knock your rears ones up (say 40psi?) to help reduce rolling resistance. :)
PostPosted: Mon Aug 01, 2011 9:32 am
Thanks
PostPosted: Mon Aug 01, 2011 11:07 am
i dont look at the rev gauge, i just rev it a bit and dump the clutch :lol:
PostPosted: Mon Aug 01, 2011 11:39 am
Not sure what revs I have aver used in any car, its just getting it right without it bogging down, don't ask Mark Webber he seems to keep getting this wrong.
PostPosted: Mon Aug 01, 2011 11:51 am
lol
PostPosted: Mon Aug 01, 2011 12:42 pm
depends on the car and setup but i held my frp around the 3k mark
PostPosted: Mon Aug 01, 2011 1:14 pm
Half throttle and DUMP!
PostPosted: Mon Aug 01, 2011 3:42 pm
Rev limiter.
PostPosted: Mon Aug 01, 2011 4:14 pm
haha
PostPosted: Mon Aug 01, 2011 7:42 pm
Well from a guy that builds and tunes race engines, and someone who I'd love to build my turbo setup but couldn't afford his service - "the best way on street tyres, is hold to use the heel of the foot on the brake rev the motor on toe to around 2k, have the clutch just at the bight point, dont slip the tyres its not worth it, just wait for the light move off the brake and lift of the clutch at the same time as WOT, best rpm range to do this on a stock motor will be sub 3.5k else you will just get wheel hop or slip"
PostPosted: Mon Aug 01, 2011 9:02 pm
hmm
reason i ask is as you might have guessed im doing some 0-60 runs at ford fair and just trying to get some tips to get the best start possible :)
PostPosted: Tue Aug 02, 2011 8:47 am
I cant launch for toffee.
Either wheel spin or get the revs too low and have no poke.
PostPosted: Tue Aug 02, 2011 11:52 am
PostPosted: Tue Aug 02, 2011 12:12 pm
Wide Open Throttle. eg. Boot it.
PostPosted: Tue Aug 02, 2011 12:40 pm
5.5k, sidestep the clutch, bang, let the 4wd do the work as you plant it :D
In your car though, you'll have to have a play on the day as conditions will affect the way you launch. There's no hard and fast rule to getting a perfect launch becaues the humidity, temperature, tyre pressures and tyre temps will have an effect. It's quite a fine art getting a great launch consistently.
PostPosted: Tue Aug 02, 2011 1:14 pm
sounds like i should just get out there and practice!
PostPosted: Tue Aug 02, 2011 2:29 pm
PostPosted: Tue Aug 02, 2011 2:58 pm
i can launch a fiesta pretty good - my ST did well last year in comparison to the others i saw - 7.55 0-60 and st's are hard to launch - as they either wheelspin a treat or bog right down :(
PostPosted: Tue Aug 02, 2011 6:10 pm
Launch Control... :)
