Fiesta-Si.com • View topic - 2.0 conversion......whats needed?
It is currently Wed Mar 11, 2026 9:28 am
PostPosted: Tue Jan 10, 2006 4:01 pm
Anybody know what is exactly needed when installing the 2.0 lump?
PostPosted: Tue Jan 10, 2006 5:55 pm
From the various posts I read today on the subject:
2.0 Zetec Lump (preferably out of a Mk2 Mondeo, Mk1 had some teething problems and Mk3 blacktop won't go in)
Gearbox. You can use either:
1.8 Zetec (from a Fiesta RS1800)
1.8 Zetec (from an Escort GTi etc)
1.6 CVH Turbo (from an Escort RS Turbo)
You can also stick with your old 1.6 box which will give better accelaration but won't go above 125mph like the other boxes.
You can use the 1.6 flywheel, and some people have put in an uprated clutch (rated up to 150bhp is fine)
2.0 ECU and MAF sensor (try and get from the same or similar car you get your lump from)
1.8 Zetec Inlet Manifold (this guy is selling them apparently
1.8 or 2.0 throttle body. You can use the 1.6 throttle cable linkage with a bit of modification.
2.0 Beige Injectors
1.6 Exhaust manifold
1.6 Starter Motor
1.6 Flywheel
1.6 Oil Dipstick Tube
1.6 Water pump and belt
1.6 Power steering pump
1.6 Alternator
1.6 Sump and oil pickup pipe
1.6 CVH (small type) Oil Filter
5 litres 5w30 oil
7 litres coolant
You might also want to uprate your brakes to Escort RS2000 or Cosworth ones to cope with the fact that you've just put a 130+ bhp lump in something that weighs about as much as a bag of nuts.
That should be it - please add below if I've forgotten anything. Good luck!
Last edited by chicken_eyebrows on Tue Jan 10, 2006 6:02 pm, edited 1 time in total.
PostPosted: Tue Jan 10, 2006 6:00 pm
Ok cheers bud, im new this forum and havent yet had chance to look around it.
PostPosted: Wed Jan 11, 2006 1:23 am
2 litre injectors aint beige?! Mine are black?
You need..
1.8 16v 2i/1.6 Si Starter Motor
RS1800 Inlet Manifold
1.8 16v 2i/1.6 Flywheel
1.8/1.6 Dipstick and Dipstick Tube
1.8 /1.6 Sump and Oil Pick up Pipe
XR2i 16v Gearbox
XR2i 16v/1.6 Exhaust Manifold
1.8 16v 2i/1.6 Alternator
1.6 Power Steering Pump
2.0 MAF Sensor
2.0 ECU
Extras:
Exhaust Joint Paste
Exhaust Manifold Gasket (1.8 16v)
Inlet Manifold Gasket(1.8 16v)
1.6 Sump Gasket
2.0 Cambelt Kit with Tensioners
1.6 Water Pump
5w 30 Oil
Power Steering Fluid
Antifreeze
Gearbox Oil
Alternator Belt
PostPosted: Fri Jan 20, 2006 10:32 pm
has some 1 done a guide???
