Fiesta-Si.com • View topic - CNC milling - help needed
It is currently Thu Mar 12, 2026 1:21 am
PostPosted: Mon Mar 01, 2010 7:00 pm
Anyone know of any places that will do custom CNC milling, need 2 exhaust manifold flanges cutting in stainless steel (10mm), 2 different manifolds designs, so one of each.
I don't have drawings, but I have exhaust manifold gaskets that I can send for them to use.
Tried google etc with no joy, just wondered if anyone had someone local to them.
Ta
PostPosted: Mon Mar 01, 2010 7:06 pm
i'll speak to alex for you(if he doesn't see this before)
i think QEP might be able to help you out with that, they near enough on alex's door step :thumbsup:
PostPosted: Mon Mar 01, 2010 7:16 pm
most mainfold plates arnt milled but just plazma/lazer or water jet cut? whats it for i also on a few kit car forums and most combinations of manifolds have been done seem around £25 each, i got my zetec one cut from a gasket for £18+P&P
PostPosted: Mon Mar 01, 2010 7:25 pm
QEP if they can do them will have one of the flanges on record at a guess, as I need a GTi/VTS one and the others is a nissan S14/15.
Milling/laser cut meh same thing!
Who did yours for £18? Need them for a little idea I've got.
PostPosted: Mon Mar 01, 2010 8:47 pm
i got mine cut in 6mm steel by shorttrack, i sent them a card board pattern which they then cut from, only thing to remember is when cut comes out slightly smaller so did need some work
http://shop.ebay.co.uk/shorttrack-motor ... ksid=p4340
other ones on ebay who might be able to help
http://shop.ebay.co.uk/bboyfastdan/m.ht ... ksid=p4340
PostPosted: Mon Mar 01, 2010 8:59 pm
Cheers fella, I'll give them a bell.
PostPosted: Mon Mar 01, 2010 9:13 pm
QEP or CDF
PostPosted: Fri Mar 05, 2010 9:02 pm
