Fiesta-Si.com • View topic - zetec on single carb
It is currently Thu Mar 12, 2026 1:19 pm
 Post subject: zetec on single carb
PostPosted: Mon Oct 05, 2009 11:49 am
is it possible to run a zetec engine on a single carb? and still use hcs wiring loom? as well as using a manual choke?
if not what needs to be done? i like to stick to carb route. im not really into big power figures.
just enough to have fun and put a smile on my face. :)
 Post subject: Re: zetec on single carb
PostPosted: Tue Oct 06, 2009 8:18 am
looks like it not possible then :doh: :lol:
PostPosted: Tue Oct 06, 2009 8:19 am
well as all zetecs run on fuel injection, i highly doubt it :)
carbs on a zetec needs different management, and thats more then one :thumbsup:
PostPosted: Tue Oct 06, 2009 8:32 am
I take it your trying to keep a conversion as simple as possible.
It could be run on a single carb it was big enough, but something from an HCS just isnt going to be enough !
You would have issue like coilpack rather than a dizzy, and with no way to power it from the origianl loom your not going to be going far. In all honesty, you would create more work for yourself by trying to do this, than just swapping everything over
HTH
PostPosted: Tue Oct 06, 2009 8:57 am
agreed with above....for the amount of work that involves...you might as well use the zetec loom and ecu with the fuel injection and that way you wont be chopping wiring and metering wires to work out what goes where
altho if its a hcs in a fiesta...past '89 (mk3 onwards) all had edis and coil packs.....still more hassle than its worth imo.
Jam.
PostPosted: Tue Oct 06, 2009 8:59 am
just bung it all in properly, with the zetec loom etc :thumbsup:
shouldn't be to hard :)
PostPosted: Tue Oct 06, 2009 9:25 am
PostPosted: Tue Oct 06, 2009 2:23 pm
ok what about zetec on twin carbs with management, would i still need zetec loom? i dont really want to go fuel injection, im old skool :lol:
and would i need si/xr fuel tank either way?
thanks for your replies :thumbsup:
PostPosted: Tue Oct 06, 2009 2:28 pm
get a cvh on carbs then if you are old skool :thumbsup:
PostPosted: Tue Oct 06, 2009 2:52 pm
zetec on carbs can be done quite easily all you need is an esc unit and loom from an old carbd cvh engine
PostPosted: Tue Oct 06, 2009 9:12 pm
cool i have a think! one more question, how much gains would i expect from 1600 zetec, 1800 zetec with 130 cams and 2l zetec, just bog standard zetec with twin carbs bolted on.
thanks :thumbsup:
PostPosted: Wed Oct 07, 2009 6:27 pm
Fit some bike carbs on it with the jets made bigger.
Run it on an ESC loom.
Job done.
Should see 140 at a guess.
