Fiesta-Si.com • View topic - asda petrol
It is currently Thu Mar 12, 2026 1:19 pm
 Post subject: asda petrol
PostPosted: Thu Sep 10, 2009 5:29 pm
does anyone else have this problem i fill up with asda fuel and the car doesnt run right at all but on other petrol runs fine :S
i dont usally fill up at asda but theres a asda on way to work i was late and fuel was in the red so not much before it ran out
 Post subject: Re: asda petrol
PostPosted: Thu Sep 10, 2009 5:32 pm
never fill up with anything other than v-power with the cossie :o :cry:
but when i had my fez i had to use a texaco garage and after i filled up, i lost all power, like i hit a massive flat spot and it would not run right :rolleyes:
never tried adsda so cant comment on that :red:
PostPosted: Thu Sep 10, 2009 6:02 pm
i only use shell now. Standard unleaded in the Micra and V-Power in the Fes.
PostPosted: Thu Sep 10, 2009 6:09 pm
PostPosted: Thu Sep 10, 2009 6:16 pm
I only go to Shell and use V-power or if not, Total. none of my cars have never run right on BP fuel, even their special stuff, and especially not on supermarket fuel.
PostPosted: Thu Sep 10, 2009 6:28 pm
PostPosted: Thu Sep 10, 2009 6:40 pm
Mine runs fine on petrol from asda.
You do know the supermarkets are just supplied by the more well known petrol places, its just which one is sorting asda near you.
PostPosted: Thu Sep 10, 2009 6:49 pm
PostPosted: Thu Sep 10, 2009 7:19 pm
the tesco performance fuel is good 8-)
PostPosted: Thu Sep 10, 2009 8:22 pm
My mondeo loves the asda diesel. runs better than when on bp or shell
PostPosted: Thu Sep 10, 2009 8:25 pm
Shell is all i ever use. Asda/all supermarket fuel tends to have addatives, and the octane rating is sometimes lower due to that, thats why its cheaper.. but makes your car run worse. It also to do with the amount of olefins in the fuel too, that basically is tar, and supermarket fuel tents to have more of that, might only be a tiny percentage (like 2%) but, it clogs up the injector needle. Therefore making it either not open properly/enough, or stay open, causing wasted fuel.. Ill stop now, i could go on for ages, did an injector cleaning course as part of my mechanics.. so know all about it lol
PostPosted: Thu Sep 10, 2009 8:27 pm
never had a problem with asda fuel, then again the engine in my sierra was designed in the stone age so will run on just about anything :lolz: altho it doesnt like sainsburys fuel for some reson.
PostPosted: Thu Sep 10, 2009 9:40 pm
i use any fuel, the cheapest.
never had a problem in any car.
when i had the xr2i i would use fourstar/lrp if i could, as it ran more efficient and better than with unleaded.
PostPosted: Thu Sep 10, 2009 11:48 pm
Asda fuel is fine for me! :thumbsup:
Does v-power make much of a difference btw?
PostPosted: Wed Sep 16, 2009 8:59 pm
PostPosted: Wed Sep 16, 2009 9:20 pm
PostPosted: Wed Sep 16, 2009 9:27 pm
PostPosted: Fri Sep 18, 2009 2:34 am
my bag of crap runs even worse when using supermarket fuel and i dont get as many miles either. not happy at it costing nearly £50 to fill the bloody thing up either!!
:doh:
PostPosted: Fri Sep 18, 2009 11:47 am
On the last RR day my C2 was drinking Tesco 99 stuff and made less than it should have.
PostPosted: Fri Sep 18, 2009 6:40 pm
on total fule mine has a flat spot from 3000rpem to 5000rpm :(
but on other fuel its ok
