Fiesta-Si.com • View topic - MOT Failed
It is currently Fri Mar 13, 2026 1:03 pm
 Post subject: MOT Failed
PostPosted: Fri Oct 10, 2008 1:25 pm
Failed on 6 items too, my main concern is 3,4 & 5. New cat? :?
Failed on 6 things
1 - N/S Front Suspension Arm
2- Centre N/S Sill excessively corroded
3 - Exhaust emissions - carbon monoxide far too high after 2 tests
4 - Exhaust emissions - hydrocarbon far too high after 2 tests
5 - Exhaust emissions - Lambda far too high after 2 tests
6 - Nearside (low) rear brake applicant uneven
CO2 or Carbon Monoxide reading, whatever it was, has to be under 0.3, mine was 5.0!!!!! Pulled the chip out and it dropped to 3.1 but still not a chance :o :o :o
 Post subject: Re: MOT Failed
PostPosted: Fri Oct 10, 2008 3:35 pm
would say new Lambda sensor and CAT by the sound of things, what engine management are you running standard closed loop or modified? you can get new CATs for about £60.
PostPosted: Fri Oct 10, 2008 4:16 pm
god knows what mine would register if the emissions were tested at MOT time
hope you get it sorted
PostPosted: Sat Oct 11, 2008 3:51 am
Management is a DEEP ECU, was with powerchip but pulled it out to see if it dropped the emissions and it did by 2 but still 2.7 over.
Car still seems to pull just fine though without flatspots, and the lambda reading on the test went green for a second so i'm just so confused!
Got a fault finder thing on its way to see if the ECU's recorded any error codes.
PostPosted: Sun Oct 12, 2008 10:18 am
hydrocarbon is unburnt fuel which would be because of the chip !
has ur exhaust system got any leaks in it ????? recently serviced?
other than that i would go to the lambda sensor, and then catalytic convertor!
PostPosted: Sun Oct 12, 2008 10:20 am
Thats not a bad fail really..
Ive never had to have any of my zetecs on emmisions so Ive never had to worry about them come MOT time :halo:
Although, sensor and cat would be a good plan, borrow a CAT if you can...
I also have the rear brake issue, we can never work out why the fook its doing it either :|
