Fiesta-Si.com • View topic - Serious anti lag !
It is currently Sat Mar 14, 2026 1:51 am
 Post subject: Serious anti lag !
PostPosted: Tue Jun 10, 2008 7:35 pm
is this serious anti lag?, god help the plants :lol:
cant think the engine and turbo will take too much of that? :shock:
 Post subject: Re: Serious anti lag !
PostPosted: Tue Jun 10, 2008 7:58 pm
fooking yes please :devil:
the tyrbo has to have a special shaft in it, a maram(sp?)247 i think its called( someone correct me if i'm wrong
i think the engine is pretty safe, if mapped etc correctly, but i'm not 100% on all this stuff, but free to correct me
PostPosted: Tue Jun 10, 2008 8:17 pm
I doubt the police sat behind you in traffic would appriciate flames all over their bumper :lol:
PostPosted: Tue Jun 10, 2008 8:27 pm
Pah thats shite, check this fo-shizzle out
http://www.youtube.com/watch?v=EeGPakSD ... re=related
PostPosted: Tue Jun 10, 2008 8:41 pm
:shock:
now that is anti-lag at its finest! :drool:
PostPosted: Tue Jun 10, 2008 9:08 pm
lol why did he try and blow it out :lol:
PostPosted: Tue Jun 10, 2008 9:26 pm
The Nude Numpty
The Nude Numpty
PostPosted: Tue Jun 10, 2008 10:17 pm
PostPosted: Tue Jun 10, 2008 11:14 pm
well i ended up watching this :) a load of footage of a rally cossie :D
doh no link lol,
PostPosted: Wed Jun 11, 2008 12:07 am
saw the rx7 vid while looking round what a moffo :devil: :o
would love to have that at 3am and drive past a certain persons house i dont like :insanity:
PostPosted: Thu Jun 12, 2008 12:29 pm
as has been said anti lag comes in various strengths. and its a special shaft in the turbo. its pretty safe if its all setup and mapped correctly and you dont sit revving it up on the spot all the time. it has got a reputation for lunching turbos due to the large amount of heat created in the turbo. hence the special shaft. im sure someone will be able to correct me on this but it was making itself known on group b rally cars...big turbo..more boost..less lag...if you go on you tube..type in group b pure sound..then listen for the quattro's....early ones were a bit ugly..but fooooooook what a noise!
PostPosted: Thu Jun 12, 2008 12:31 pm
the shaft in question is a mariam shaft 8-)
PostPosted: Thu Jun 12, 2008 1:51 pm
Lower boost thresh hold. lag is time it takes to create boost once in the threshhold.
its MAR-M 247 shaft, its a type of metal
large amounts of heat are created due to the way this type of ALS works. depending on the harshness of the ALS over 300c extra can be seen in short periods of time. thats near death time for the standard manifolds,
PostPosted: Thu Jun 12, 2008 1:56 pm
i can try and discribe how it works if you want....
PostPosted: Thu Jun 12, 2008 2:07 pm
go for it boost mad!
PostPosted: Thu Jun 12, 2008 2:14 pm
basicly, how i understand it ( well , how it works on a cossie )
The ignition is retard by aroun 60-90 degress there for making the combustion process happen when the exhaust valves are open. there for all the heat and "bang" goes straight into the exhaust spinning the turbo.
because the combustion basicly goes straight out the exhaust and isnt contained in the combustion chamber the heat goes out the exhaust too.
you can run on a cossie about 1psi of positive pressure without a mar-m shaft but only for short periods... rally stages are a no no lol
Its requires mods to the ISCV and TB on a cosworth engine, also a new chip and software for the ecu
PostPosted: Thu Jun 12, 2008 2:41 pm
PostPosted: Thu Jun 12, 2008 2:54 pm
oh yes.
some cars have a seperate bypass valve rather than a modded iscv.
modded iscv is only for very mild applications realy
