Fiesta-Si.com • View topic - Info on 2.0
It is currently Sat Mar 14, 2026 12:14 am
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Info on 2.0
PostPosted: Wed Jun 11, 2008 2:56 pm
you got a link?
i wanns see this :devil:
if it is as easy as he says, it must go pretty well, whats the rs2000 engine like for tunability?
PostPosted: Wed Jun 11, 2008 2:57 pm
really bad. you can get 160hp quite easy but anything after that is £££££££££££££
I would show you the link but you will have to register ???
Mk5 RS2000 silver
Mk5 RS2000 blue
"money won is twice as good as money earned"
PostPosted: Wed Jun 11, 2008 2:58 pm
:shock:
so its a little worse than the zetec engine then :cry:
have you thought about going throttle bodies and MS?should see 160-180bhp at a guess
PostPosted: Wed Jun 11, 2008 3:00 pm
unless you take the TB route its not tuneable as such
but i would think a fiesta with 148bhp and 140lb.ft torque or there abouts would be a laugh!
PostPosted: Wed Jun 11, 2008 3:01 pm
:) :) ill find out soon 8-)
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Wed Jun 11, 2008 3:03 pm
you could go MS and TB's for a few hundred quid :chill:
let us know what you find :D
PostPosted: Wed Jun 11, 2008 3:10 pm
on the RS2000 forum there is a guy that can do anything for the right ££ so ill see. ill be doing all this to the fez and i wont do it to my own RS2000 lol
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Wed Jun 11, 2008 5:07 pm
On the RS forum They 110% sure it will fit simple but the gearbox wont.
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Wed Jun 11, 2008 5:17 pm
There was one on ebay a while ago with RS2k engine fitted.
Go for it if you can be arsed with the hassle, but I doubt it will make much difference.
PostPosted: Wed Jun 11, 2008 5:21 pm
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Wed Jun 11, 2008 5:38 pm
not an Si but a 1.1 mk3.5,people talking bout it etc.
http://passionford.com/forum/showthread.php?t=236933
PostPosted: Wed Jun 11, 2008 6:11 pm
Ive got a 2litre Si as purly a track day car my opinions are
Reliability
Yes generally when set up and sorted (suspention brakes ect). only thing ive had is clutch problems got through 2 cheap ones in 2 1/2 track days. but now fitted a Helix uprated 1 so hope this will sort this out. It's also got the usual water leaking problems, and Rust which may not be as much of a problem on Corsa.
would they keep up with Redtop Corsa's
think you also need to look at what tracks you are going to visit for corner speed or top end, i am supprised even at snetterton what i can keep up with/ahead over a full lap running on Toyo Proxies. the handling and corner spead will be better in a fiesta as dont think corsa have both front and rear anti roll bars and not as wide track.
Mine is only rumming at 133BHP but would expect a basic Redtop to be higher and easier and cheaper to tune higher than a zetec.
with referance to gearbox discussion ive still got the 1600 which tops out at about 120, but rearly strong 40-110mph, think the RS Escort series 2 gearbox with LSD woud be best, but again would depend on what tracks you looking at if lots os slow corners LSD beneficial if more faster sweaping corners with no great long straights expect 1600 still be good.
Petrol
if you are looking at track days dont think this should be looked at as an issue, both will be bad and expensive!!
Tunable
150bhp accesable with standard 130bhp cams/head exhaust manifold and throttle bodies/engine management which will cost any thing between £500-£1900
Lots of second hand stuff about for red tops though as been about for some years and will ultimatly achieve higher BHP.
My sumary is Si will out handle Corsa but may not have legs on straight, but you can get a long way ahead throught corners that it still wont catch you by end of straight:lol:
PostPosted: Wed Jun 11, 2008 6:40 pm
PostPosted: Wed Jun 11, 2008 7:38 pm
what is it with corsa red tops?
good read, some interesting points
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Jun 11, 2008 8:00 pm
PostPosted: Wed Jun 11, 2008 8:15 pm
well basically the redtop corsa is the equivalent conversion to the fiesta. we recently raced one (on private roads of course) and it completely wasted us. so i set my target on beating them. which is a good target me thinks.
Here is what i think it will take.
- Fiesta Si. £300 - £800
- I4 (RS2000) engine. Got
- Koni Adjustables. £400 (Or Second hand)
- Toyo Proxies £230
- Strut Brace Front & Rear. £150
- Mondeo Calipers £50
- St170 Discs £120 Drilled & Grooved
- Lightened & Balanced Flywheel £120
So all in all Maximum £2000 Ish
Which All in All sounds like it make a cheap street sleeper :lol:
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Wed Jun 11, 2008 8:24 pm
Oh some one just told me how to save the 12kg.
Move the battery to the boot. :banghead: why did'nt i think of that.
Mk5 RS2000 silver
Mk5 RS2000 blue
PostPosted: Thu Jun 12, 2008 10:17 am
PostPosted: Thu Jun 12, 2008 10:30 am
i was thinking that also! :lol:
PostPosted: Thu Jun 12, 2008 10:42 am
