It is currently Fri Mar 13, 2026 12:22 pm
Post new topic Reply to topic  [ 2515 posts ]  Go to page Previous  1 ... 81, 82, 83, 84, 85, 86, 87 ... 126  Next
PostPosted: Mon Aug 16, 2010 9:05 pm
Washed it :) Happy with the results. (See Proj Thread)
PostPosted: Mon Aug 16, 2010 9:19 pm
from memory im sure the current speakers are all 13cm :P got one in my room so i'll jus tmeasure it!...
PostPosted: Mon Aug 16, 2010 9:36 pm
13.5 mate!
PostPosted: Mon Aug 16, 2010 10:53 pm
tried to stop the cd played flying out when i pull off
To rebuild?
PostPosted: Tue Aug 17, 2010 7:28 am
13cm speakers fit :)
i'v had 7 mk3's :lol:
PostPosted: Tue Aug 17, 2010 5:55 pm
cleaned the spark plugs, fitted new blue hose on the air box sensor
PostPosted: Tue Aug 17, 2010 7:49 pm
cool cheers ben. thanks mate. :thumbsup:
PostPosted: Tue Aug 17, 2010 9:40 pm
got coverd in shud when i change the clutch and drained the gear box oil all good fun :)
PostPosted: Wed Aug 18, 2010 7:48 am
Prepping the Mk2 for the MOT re test :cry:
PostPosted: Wed Aug 18, 2010 8:27 pm
well went to put the car back to gever but the bolt on the top off the sus crossfreded :x so now the new lowering spring is on my old shocker :x
on a + side the copper brake line are undone ready for the new ones ow and i now have new gear box oil :)
PostPosted: Wed Aug 18, 2010 8:33 pm
I havent but the missis give my headlining a good clean as it was manky, i mean a good 2hours havin a bash at it while i was at work. You lot should learn from this, if the other half isnt cleaning your pride and joy when your at work then get it sorted! lol
PostPosted: Thu Aug 19, 2010 5:45 pm
PostPosted: Thu Aug 19, 2010 6:50 pm
I refitted my wing-mirror after an incident yesterday, cleaned it and then it rained...
PostPosted: Thu Aug 19, 2010 8:08 pm
it lives :D
and taken of harf the brake lines but then it started to tip it down :x
PostPosted: Thu Aug 19, 2010 8:44 pm
woohoo
PostPosted: Thu Aug 19, 2010 9:00 pm
i take it you like the rain :lol:
PostPosted: Thu Aug 19, 2010 9:56 pm
my head gasket went on the way to work yesterday and today ive been taking it off, well what i can get off in the time i got lol.
take the cam belt off and the head off tomorrow and hopefuly just nee the gasket and head set nothng set.
PostPosted: Fri Aug 20, 2010 6:17 am
PostPosted: Fri Aug 20, 2010 6:24 pm
finished work and decided to put some new lights on the corsa as its time to try and improve its looks so its semi debadged (corsa has been removed, just vauxhall left) but anyway, the problem with fitting new lights to corsas is the front bumper has to be removed!! i undid everything apart from the drivers side plastic nut which is being a nob and just not coming off, passenger came off ok. but my efforts have been put on hold because its just pissed it down so im wet through!!! thats what iv done to the missis car anyway
PostPosted: Fri Aug 20, 2010 9:07 pm
i got it even dirtier
