It is currently Sun Jul 22, 2018 12:30 am
 Post subject: red line
PostPosted: Sun Mar 07, 2010 11:26 pm
Drives: 02 phase 2 zs
why do some si's have red lines and others dont ?
 Post subject: Re: red line
PostPosted: Wed Mar 10, 2010 4:08 pm
Drives: XR2i 2.3 Turbo
They all do.
http://www.fiestamk7.com - A forum dedicated to the Fiesta Mk7 - 1 year old and going strong!
http://www.fiestamk3parts.com/ Info and guides on the Mk3 Fiesta
PostPosted: Wed Mar 10, 2010 4:45 pm
Drives: C2 VTS
Just to check, where is this readline you speak of?
If you mean on the rev's they all have a limit.
PostPosted: Wed Mar 10, 2010 4:47 pm
Drives: Fiesta ZS
Do you mean like in the 1.4 the rev counter dosen't show a redline? and the 1.6 Shows a red line?
There was no limiter on my 1.6 so you had to use the red line, and I never got my 1.4 past 5,000 RPM so i'd have no idea if there was a limiter on that model. But I am assuming the reason they haven't put red on the rev counter of a 1.4 is because theres a limiter...
This could just be a completely irrelevant answer..
PostPosted: Wed Mar 10, 2010 7:24 pm
Drives: V6 Cougar
my 1.6 doesn't have a 'red line' (on rev counter).
wondered why myself tbh
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Mar 10, 2010 8:23 pm
Drives: Si 1.6 & ST170
i dont think mine does either, i never take mine past 5500rpm because i dont think theres much pull after it.
The Loumiester wrote:
Ford is not a decision you make to like, its a passion you grow up with.
PostPosted: Thu Mar 11, 2010 9:14 pm
yh i mean on the rev counter
mine dont have 1 but some others do
i dont rev he engine that high as im not that brave + the first time i do it something will brake
PostPosted: Fri Mar 12, 2010 4:32 pm
Drives: Fiesta Si 2.0
Fair few fiesta's dont have that red marking on the rev counter. And the rev limiter is about 7500 i think... just to let you know lol
TTF Si Project thread
PostPosted: Sat Mar 13, 2010 12:31 am
Drives: Fiesta ZS
I know I went over the rev counter, never hit the limiter though :P thought there wasn't one
PostPosted: Sat Mar 13, 2010 7:16 pm
Ive hit it once, it was as a test to see if it was working correctly, and it was......... lol
PostPosted: Sun Mar 14, 2010 11:17 am
i thought there wasnt one, 7500rpm though, i dont think im that brave lol
PostPosted: Sun Mar 14, 2010 9:42 pm
i get scared wen i nearly hit 6000rpm never mind 7500rpm
think i shall give it a miss
PostPosted: Sun Mar 14, 2010 10:59 pm
Drives: Fiesta ZS
lol my old si used to sound awesome going up to 6500rpm. Thats when you hit the red line, so you can do that alright, but obviously ragging your car around alot won't help it too much.
and going over it isn't going to help at all :P I did it once by mistake, the gearstick practically changed gear on its own :lol:
PostPosted: Tue Mar 16, 2010 1:21 pm
screw that im scared just reading ur post :doh:
PostPosted: Sat Apr 03, 2010 8:15 pm
Pah!
I think the limiter is set at 7100rpm, sure I read that somewhere!!
Mines regularly goes past the redline on the rev counter and the 7 on the dial but I've only hit the limiter once I think!
But then I am screaming for an excuse to drop my 2.0 litre in ;)
Paul
*edit to change redline to limiter!! Think it makes more sense now :thumbsup:
PostPosted: Sat Apr 03, 2010 8:39 pm
Drives: Fiesta ZS
Well what do you class as a "red line" I class it as the coloured in red square on a rev counter, which would be 6500rpm on an si. Then the limiter kicks in.. And that's a limiter to stop you blowing the fucker up :P
although you might not have a red square on your counter? That's why you think that. Not having a go, which it might sound like, just interested to see opinions
PostPosted: Sat Apr 03, 2010 9:42 pm
Drives: Jap Crap
you're redline should be somewhere around there < :P
PostPosted: Sat Apr 03, 2010 10:19 pm
Drives: Fiesta ZS
RX-7/8 red line :gheeyyy:
