Fiesta-Si.com • View topic - A4 Cabrio V6 TDI - New cosmetics plus a power upgrade
It is currently Thu Mar 21, 2019 6:53 am
Post new topic Reply to topic  [ 360 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 18  Next
PostPosted: Wed Mar 28, 2012 9:52 pm
A lot of turbo engines will probably use 15% less fuel rather than more depending on driving styles
PostPosted: Thu Mar 29, 2012 9:42 am
Its not fair the cruise control on your leon is cheaper to get fitted than on my audi :lol: my partner has cruise as standard on her audi a3 2.0 tdi and i see what you mean as bout the freakyness! I like the fact that you can stikl overtake with it and then it brings you back down to your original cruise speed!
How much did your miltek set you back? If you dont mind me asking. Looking forward to a vid of it!
PostPosted: Tue Apr 03, 2012 5:33 pm
vid here mate
was about £500 with decat and £80 for fitting
PostPosted: Fri Apr 13, 2012 10:34 am
any more updates ?
PostPosted: Sat Apr 14, 2012 11:38 am
One very small thing done, not really a mod but a fix and an add on extra!
Most common issue with the a4 B6 and B7 is that the glove box hinge brakes, when i bought the car i didnt even think of opening the glove box as its not usally something i check when buying a car :lol: Anyway on the way home when i bought it my partner opened it and the hinge was broken. Basicly the reason this happens is because audi fitted a piston that makes the glove box door open slowly so it doesnt slam open, over time this piston gets stiff and eventually you have to putt the glove box open which results in the hinge snapping as its weak! So anyway i set to repair it as cheap as possible as didnt want to buy a new gloe box from audi for £100+! so i drillied 3 holes through the two broken sections of the hinge and then cut the heads of some nails and then slid the nails through the two parts of the hinge and glued in place! and removed the piston from the hinge. door opened fine but the glove box light didnt some on as the swich for that was fitted into the piston :doh: so here is how i got around that...
I went to Maplin and bought a push to brake swich.
i Then removed the entire glove box from the car, only 4 bolt held it in which i was pleased about! when i got the box out i noticed this..
there was a blanking plate for another glove box light, so i though ah i have loads of audi interior lights sitting in the garage waiting to be fitted for my lighting pack. so i popped the blanking plate out, so i was left with this.....
i then checked to see if my spare light would fit, which it did!
So i set about doing the wireing (turned from fitting a swich to addign a new light and fitting a swich :lol: )so i got a OEM plug a lead from my box of cables i have lying around 8-)
I then opened up the connector for the origional light and solderd the new cable and plug into that and then wrapped the cable in loom take to keep it looking factory(although you cant see it when fitted :lol: )
Light all wired in
After that i set about sorting the swich, here is the hinge where the piston was fitted and the cable for the swich
And this is where i was relocating the swich to, its where their used to be a litted rubber stopper at the top of the glove box
i drilled this out to the size of the swich and fitted the swich
i then set to work on wireing it up, i moved the plug for the original swich the top of the box, i then solderd another OEM plug and cable onto the new swich and wrapped in loom tape and plugged into the origional swich plug
and here is the finished result
Although its only a standerd feature in a car im well chuffed with it, took me about an hour to do but its nice having a glove box that opens and closes properly :halo: :halo:
Going to give the car a good polish later if the sun stays out, pics to follow :D
PostPosted: Sat Apr 14, 2012 5:18 pm
Spend about 4 hours today cleaning and polishing the audi and also fixing the boot luggage compantment as it had broken which was annoying me, if something is supposed to work i like it to work :lolz: im fussy.
Pics of the car, i was never happy with the shine of the body when i got it so i thought id take some time tarting it up, some parts i had to wet sand as in places the laqure was gritty guessing its had a respray on the passengers front wing, also the orange peal was quite bad at the top of the drivers door and rear quarter so this was wet sanded too!
Sun went down so the photos dont do it justice and they were taken on my phone so quality isnt the best :(
And the fixed luggage compartment, this used to just stay down as i couldnt rise it as a clip inside had broken.
Close
Pull the lever around at the top when the roof is up and gives you more boot space 8-)
PostPosted: Sun Apr 15, 2012 7:07 pm
ohhhh very nice :D
PostPosted: Sun Apr 15, 2012 7:44 pm
Car looks lovely on those pics, the interior also looks like a nice place to be.
PostPosted: Mon Apr 16, 2012 9:01 am
good work there jamie ;)
PostPosted: Mon Apr 16, 2012 6:03 pm
cheers guys, tbh its the nicest car i have driven, just so compfertable and is a very nice place to be 8-)
Going to attempt to fit my lighting pack tomorrow following a guide of the audi forums, hope its not to painfull to do :lol:
PostPosted: Tue Apr 17, 2012 4:21 pm
Looks stunning in the pics, good work :chill:
PostPosted: Tue Apr 17, 2012 6:13 pm
Thanks Dave 8-)
Been busy today, took a trip to the breakers again today to see what Audi's they had down their. I wanted to find an Audi with the lighting pack installed so I could get the genuine Audi door looms for the puddle lights and red door open warning light. After searching all the cars I had no joy untill I found a 2001 Audi A6 hidden away right at the back of the yard, pulled the door card off and hay presto, it had the full door lighting pack including inside soor handle ambient lighting!!!! so that behind the door handles glows Red at night when the lights are on. Unfortunatly I will have to cut a slit into the top of the inner door handle surround to fit these which I can't do untill I get my demel in 2 days. Anyway took the door cards off, fitted the lights (holes were already their so i just had to pop them in) wired them up to the door loom so its as it would have been from factory and they work as they should 8-)
When the door catch is in the closed position the lights are off
When the door is opened they come on!
Going to take a shot at doing the footwell lights tomorrow but I havnt been able to find a guide to them yet so will have to go blind with that :lol:
PostPosted: Tue Apr 17, 2012 6:23 pm
Very smart Jamie!!
PostPosted: Tue Apr 17, 2012 8:00 pm
Good work Jamie 8-)
PostPosted: Tue Apr 17, 2012 9:59 pm
Cheers guys, really happy witht he outcome of these, they just add to the car, really want my foot well lights done now! ill crack on with them tomorrow :)
Heres some bad photos of it tonight in the dark, really bad quality from my phone at night!
I also changed the colour of my glove box lights to red which my brother in law suggested i did. Think it makes it look amazing! fits in well :)
PostPosted: Tue Apr 17, 2012 10:10 pm
I like!
Footwell lights will finish that off perfectly!
PostPosted: Wed Apr 18, 2012 12:51 am
Iam actually really liking this car, if I hadn't already spent as much on the Leon I could be tempted by one of these myself.
What's the performance and MPG like ?
PostPosted: Wed Apr 18, 2012 8:53 am
good work - looks really good
PostPosted: Sat Apr 21, 2012 6:45 pm
PostPosted: Sat Apr 21, 2012 6:57 pm
Good work 8-)
Looks like the swans liked it too :thumbsup: :lol:
