It is currently Wed Jan 16, 2019 12:49 pm
Post new topic Reply to topic  [ 365 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19  Next
PostPosted: Fri May 10, 2013 11:11 am
looking really good there buddy, but i prefer the look of these lights
breaks the black up a bit :thumbsup:
PostPosted: Fri May 10, 2013 11:31 am
Drives: BMW E90 330D M Sport
Cheers, yes there the ones iam using again, got rid of the other ones.
PostPosted: Fri May 10, 2013 11:58 am
Drives: Mk1 FRS and FRST
Looking good buddy :thumbsup:
PostPosted: Sun May 19, 2013 8:36 pm
think i fancy the new leon mk3 next year maybe. the 150 tdi DSG model, either in black or white
new pics of the MK3 Leon Cup
PostPosted: Sun Jun 09, 2013 5:35 pm
Some of my new Dodo Juice cleaning gear
New Driveshaft & studs, Wishbone and ball joint fitted (needs tracking now cause its way out)
New reverse camera and relocated out of plate and central to rear bumper in the numberplate recess, new plates fitted without GB logo and some dodgy spacing.
PostPosted: Sun Jun 09, 2013 8:31 pm
wow. Fantastic work.
new cleaning stuff looks spot on. Do you always get dodo stuff?
How much does a new driveshaft set you back on a leon? you do both sides yeah?
PostPosted: Sun Jun 09, 2013 8:50 pm
i have lots of cleaning gear, but Dodo is my favorite right now
Driveshaft was £125, wishbones £30 each, lower ball joints £10 each. Changed wishbones and ball joints both sides but changed only n/s shaft cause the outer CV joint had gone
PostPosted: Sun Jun 09, 2013 8:55 pm
Christ. you notice a difference?
Did you wire in the rear camera from scratch?
PostPosted: Sun Jun 09, 2013 9:17 pm
Difference with the Dodo Juice ? if so then yes, its pricey compared to run of the mill stuff but gives very good results and easy to work with
yes its pretty easy, just a video feed from the headunit, then a live and earth for the camera, also headunit has camera detection so soon as i put in reverse the camera comes on automtically. Camera was only £20....ebay jobbie
PostPosted: Sun Jun 09, 2013 9:34 pm
Brilliant. Bet your made up. You must be running out of creature comforts to put in there surely?
PostPosted: Sun Jun 09, 2013 9:40 pm
yes nothing else to do inside really. just needs bodywork tidying up and lots more power to keep me happy really.
PostPosted: Sun Jun 09, 2013 9:52 pm
lol love it!
Looking forward to seeing it progress!
PostPosted: Sat Jun 15, 2013 7:40 pm
Very nice, like what you have done with it :)
PostPosted: Sat Jun 15, 2013 11:24 pm
new driveshaft fucked !
The inner CV boot was destroyed by the securing clip digging in to the rubber boot causeing a split and it turned the driveshaft rotation destroyed it. Returned for full refund so trying to collect a 2nd hand unit off ebay tomorrow for £30, ill drive that till it dies then be seeking another new one, VW want £315 for one :shock:
PostPosted: Sun Jun 16, 2013 9:28 am
Not good fella :shock:
Hope you get it sorted :thumbsup:
PostPosted: Tue Jul 30, 2013 9:17 pm
well the clutch and DMF finally gave up, so ive ordered a Sachs Racing stage 2 Organic clutch and SMF kit that will hold nearly 400Ft/Lbs+ of torque......at a very very shocking in a bad way price :shock:
Hoping to get fitted within a week, then on to a R-Tech stage 1 map to see about 195BHP and 320 Ft/Lbs+ of torque
should see 0-60 in low 7's high 6's and top end of about 140 MPH whilst maintaining an average 45MPG
PostPosted: Wed Jul 31, 2013 8:08 pm
Drives: Fiesta ZS
Vag clutches are ridic prices.
PostPosted: Tue Aug 06, 2013 3:49 pm
So the new Sachs SRE organic clutch and SMF kit arrived. Capable of 390Ft/Lbs+ of torque so future proof any performance upgrades i make. Also the uprated Audi TT and superpro wishbone bushes arrived
Old clutch out, the center of the clutch disc detached. Cant complain as the original clutch and DMF setup lasted 192K :)
PostPosted: Tue Aug 06, 2013 3:50 pm
New clutch is in, but not liking how it feels, dont know if it needs bedding in or its the way its been installed or setup. Biting point is high on the pedal, and when you find the biting point the car just wants to run away, this will make stop start traffic rather annoying. Its like it only has 2 speeds, stop and run as fast as you can, there's no slipping though, just hard to get the clutch\power balance for slow cruising with such a small area of pedal travel that dosent have a gradual bite :confused:
plans for the rest of the week are get new steering rack, track rod ends, superpro wishbone and steering rack bushes, Audi TT uprated wishbone bushes, and o/s ball joint installed. Change gearbox oil and also need to get a nail removed from rear tyre, 4 wheel alignment and MOT.
PostPosted: Wed Aug 07, 2013 11:58 pm
Wishbones that are only a few months old from Europarts are off the car, already bushes have cracked, so prepping them for the Audi TT uprated bushes along with superpro bushes.
Drilled out the old bushes
Uprated solid Audi TT and Superpro wishbones bushes in and cleaned up the wishbone. Getting the TT bushes in without a vice was a fucking nightmare :x
Also received the superpro steering rack bush, to go on with the new steering rack
