It is currently Fri Feb 22, 2019 5:19 pm
Post new topic Reply to topic  [ 365 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19  Next
PostPosted: Fri Mar 22, 2013 7:07 pm
Drives: Mk1 FRS and FRST
Liking the stealth look :thumbsup:
PostPosted: Sat Mar 23, 2013 5:11 pm
Drives: BMW E90 330D M Sport
Cheers
Ordered some custom decals for the tailgate and and the windscreen.
Still undecided on the full rear tints and iam worried it might look a little shit. might try and find another pair of rear lights and experiment with E-Tech tint spray, flyeyes and lamin-x and see what gives the darkest but best oem style look. Also worried about the mot\reflectors\police issues of full rear tints
wheels might get changed again at some point for a staggered set of 18" gloss black 3SDM 0.01 or XXR 530 8.5j\9.5j
photoshop pics of my decal ideas
Windscreen
Front Wing
Tailgate (with smoked rears)
PostPosted: Sun Mar 24, 2013 10:38 am
liking the work, looks cool mate
PostPosted: Thu Mar 28, 2013 9:10 pm
Drives: Suzuki Ignis Sport
looks awesome!
PostPosted: Mon Apr 01, 2013 8:51 pm
Fitted the "Stealth Edition" window decal. Just need to lower the tax disc out the way
Started to take the brembos to the bear metal. Once ive got all the paint off ill smooth out the metal finish then need to pick up some Hammerite paint primer tomorrow as paint on bear metal alone isnt going to work. Also need to pick up some more sanding accessories for the Dremmel to get into those hard to reach places. Hoping by end of tomorrow have them sanded and in metal primer, then the following night paint them and leave a few days before fitting. will also allow time for the Brembo decals to arrive from a ebay purchase
Not sure if i should spray paint the primer or hand brush the primer and sand it flat afterwards to help fill any imperfections in the metal
PostPosted: Tue Apr 02, 2013 11:24 am
I would use spray can filler primer, then sand it flat :)
PostPosted: Tue Apr 02, 2013 11:45 am
Drives: Sideways
Would that take the heat?
AUTOBAHNSTORMERS
PostPosted: Tue Apr 02, 2013 1:15 pm
It should do in theory, but you never know until you try it. But to be honest, if you are using hammerite, there isn't any need for primer :)
PostPosted: Tue Apr 02, 2013 8:36 pm
The hammerite red I got is in a spray can and is very thin, too thin to try and cover bear metal. I got some hammerite special metals primer in a tin which is thick. Just brushed on the first coat. Ill give it another coat with the primer so it's smoother and covered any blemishes in the metal, then sand it flat with 2500 grade. Then on to several coats of the spray can red. No lacquer needed. Then apply the brembo decals
PostPosted: Wed Apr 03, 2013 4:39 pm
primered then painted, heat proof decals also arrived.
looks like the paints gonna take weeks to harden
PostPosted: Wed Apr 03, 2013 5:48 pm
Nice indeed. Should look spot on when all finished
PostPosted: Wed Apr 03, 2013 7:29 pm
hope so.
got these ready to go on when the calipers have fully cured
PostPosted: Wed Apr 03, 2013 9:46 pm
decals on
PostPosted: Wed Apr 10, 2013 7:43 pm
started fitting the Brembos. Iam missing the pad retaining clips so not bleed the brakes until i can source the clips
before i started
Old discs and carrier off
old vs new
jet washed it all out while i was there
new discs and dust shields fitted
brembos and badger 5 braided hoses fitted
wheel back on
PostPosted: Wed Apr 10, 2013 7:44 pm
led rear lights fitted. tinted them with e-tech tint spray for the stealth look. think i went too dark though, might re-do them at some point to a grey\brown tint level.
not liking the lights, think it cheapens it and the old ones looked better :?
also added rear decal
PostPosted: Wed Apr 10, 2013 11:03 pm
Think iam going back to my old lights cause there not growing on me
95 Fiesta Si wrote:
PostPosted: Thu Apr 11, 2013 9:08 am
I thought an all black rear end would look quite good, how wrong I was. The old ones give some sort of fresh look to the car. They will match the brakes too :)
PostPosted: Thu Apr 11, 2013 9:40 am
Drives: Sideways
Step back a bit. Gi's a wider shot.
AUTOBAHNSTORMERS
PostPosted: Sat Apr 20, 2013 4:57 pm
the black rear lights did look proper shit. keeping the old units on, iam going to lamin-x them, took make the red abit darker
PostPosted: Fri May 10, 2013 10:48 am
Took a few pics over the weekend as it was nice and sunny, so gave it a quick clean up, starting with all the door hinges and seals.
