It is currently Fri Jul 20, 2018 5:46 pm
 Post subject: Best way to use T-cut?
PostPosted: Wed Jul 08, 2009 11:06 am
Drives: Clio Rs197
So I'm planning on giving the car a really good wash when the rain eventually buggers off. Brought some T-Cut (the metallic one) to get out a scratch and a few other areas that need attention.
Never used it before so coming to the people who know what they are doing.
Whats the best way to use T-cut? :hsugh:
PostPosted: Wed Jul 08, 2009 11:29 am
Carefully. T-cut is not demishable, meaning it will keep cutting away at you paint. where as compounds like Poorboys SSR range, megs 80-83 etc are deminishable, meaning that the cutting abrasive in them breaks down and turns into a polish.
Just take it easy, dont get any on unpainted plastics, and, i assume by you asking this question that your not using a machine to polish which is a good thing ( with T-cut )
HTH
PostPosted: Wed Jul 08, 2009 1:28 pm
Drives: Clio Rs197
So the way I was going to do it, put a little on a cloth and wipe the area over with it then wash off once finished, is an ok way to use it?
PostPosted: Wed Jul 08, 2009 1:41 pm
wash and dry the car as normal.
apply the tcut in small amounts either straight to the panel or to a cloth and work in with gentle pressure. doing small areas at a time ( 1' ). once it has dried to a haze ( you will be able to tell by touching it, it shouldnt feel wet lol ) buff off with a clean cloth. DO NOT at anytime apply water to the t-cut you will spend ages trying to get it off :thumbsup:
PostPosted: Wed Jul 08, 2009 3:37 pm
Drives: Clio Rs197
ah good so I did figure right. I'll have to do this next time as I've just washed and waxed it. Looking good so far
Think I'm gonna run the car through a bodyshop to get the car done properly (nearer to christmas) as I was waxing it quite a few patches needed proper attention. The paintwork is mostly ok but there are areas where I'm getting white specks (1 on the front passenger door and one on the wing by the drivers door) so need to sort those out.
I'm loving driving this car and am noticing that it does get quite a few looks 8-)
PostPosted: Wed Jul 08, 2009 4:00 pm
get some pictures up.
what needs doing that you need to go to a body shop ?
PostPosted: Wed Jul 08, 2009 10:10 pm
Drives: Clio Rs197
I'll grab some pictures tomorrow of the patches but basically to explain it.
Its these white dots that don't clean off, I did try a bit of T-cut on them but it made no difference just took off all the dirt that had built up on top of them. As I said I'll grab some pictures of it tomorrow so you can get a better idea of what I mean. :)
PostPosted: Wed Jul 08, 2009 10:32 pm
I will have a look at the pictures for you, see if we can advise you further.
you going to ford fair ?
PostPosted: Wed Jul 08, 2009 10:51 pm
Drives: Clio Rs197
When and where is that?
Kinda new to all the ford events :o
PostPosted: Wed Jul 08, 2009 11:04 pm
its at silverstone on the 2nd of august.
PostPosted: Wed Jul 08, 2009 11:06 pm
Drives: Clio Rs197
Depends on if I'm working that day as I'm starting a new job and have yet to get my shifts in
PostPosted: Thu Jul 09, 2009 8:40 am
If you do, let us know.
These things are easier to diagnose when you actualy see them
PostPosted: Fri Jul 10, 2009 4:09 pm
Drives: Clio Rs197
ok here is the pictures of the white dots and a few other problem areas. There are some patches on the car that defo need a look by someone from a bodyshop as there are patches on both rear arches that the colour doesn't match (I'm planning on making this car look mint so I'm gonna make sure its all good)
2 White dotty patches
Passanger side back door
Front drivers side wing
There is a scratch T-cut wouldnt work on and a patch I just noticed while taking the pictures
Back
By the back passenger door (passenger side)
Also just a sidetrack what is the best way to clean these up (as I've tried to scrub them with my dads alloy cleaner brushes but made little difference)
Both front ones are like that
The back ones are like this though :D
(yes I'm aware of the rust patch its TBS when I get the money together)
PostPosted: Fri Jul 10, 2009 4:11 pm
Drives: Sideways
Toothpaste :thumbsup:
AUTOBAHNSTORMERS
PostPosted: Fri Jul 10, 2009 4:55 pm
Its hard to tell from the pictures what the dots are, do they stick out, or are they more like little chips. ?
PostPosted: Fri Jul 10, 2009 5:09 pm
Drives: Clio Rs197
no they don't stick out at all I've ran my nails over them and the surface is smooth its like they are in the paintwork but they weren't there before I cleaned the car at the weekend. Thats what puzzled me about them. The ones at the front show up clearer as I waxed 1/2 the car before it started to rain (still got the passenger side and front of the car to do)
Ill have to try the toothpaste any particular type or whatever takes your fancy :hsugh:
PostPosted: Fri Jul 10, 2009 5:18 pm
Drives: Like a boss
not too sure about toothpaste but bug and tar remover works a treat on brake dust, :thumbsup:
PostPosted: Fri Jul 10, 2009 9:18 pm
Drives: Clio Rs197
I'll keep a look out for that, my dad might have some as he is OTT with the cleaning of the Saab and has most cleaning stuff you could need for it. I'll let you know how I get on with it as I might try it tomorrow, cleaning the car is a good way to chill out.
PostPosted: Fri Jul 10, 2009 9:21 pm
Drives: Sideways
Anything cheap. Suprisingly effective due to an ideal PH balance :nerd:
AUTOBAHNSTORMERS
PostPosted: Fri Jul 10, 2009 9:29 pm
Drives: Clio Rs197
well if it works it works and itll save money if it does. Plus I can use whatever doesnt get used on the alloys as...um....oh yeah toothpaste :lol:
