It is currently Fri Jul 20, 2018 7:38 pm
 Post subject: Sticky Stuff
PostPosted: Thu Sep 25, 2008 8:41 pm
I removed the fiesta badge but it has left the glue how do you get rid of this because i bought a new badge and need it clear to place it
thanks
 Post subject: Re: Sticky Stuff
PostPosted: Thu Sep 25, 2008 8:44 pm
Drives: MK3 Fiesta
hi there, try and rub a load of vinegar on it with a damp warm cloth.
if not, try something like pure lemon juice or anything with a nice bit of acid in it.
hope this helps.
jollyxr2i.
1994 Ford Fiesta, 1.1 rattler. Tourmallard Green, RST alloys, with some twin piped rear silencer (<--- ha, the irony)
S reg Volvo C70 2.5 MPi low compression turbo
PostPosted: Thu Sep 25, 2008 8:47 pm
thank you so much because everything other people have said has made it worse
will try this on saturday and also when i removed the rear ford badge it left a imprint of were it was like rings or glue
shoudl i t cut it and try get the shine out of it or what
thank you once again
PostPosted: Thu Sep 25, 2008 9:42 pm
IPA or white spirit as a last alternative
you can get "sticky stuff remover " from some places
or bug and tar remover
what have you tried already
PostPosted: Fri Sep 26, 2008 12:36 pm
just warm water so far
but i really need it off because im putting new badges on and i want it to be a clean bodywork
PostPosted: Fri Sep 26, 2008 1:58 pm
Drives: Audi A4 Cabrio v6
heatgun or hairdryer, run it over it for a little bit, if you use a heatgun hold it a fair bit away so you dont burn the paint. shocd melt the glue and then get a glove or even just a cloth and rub it and it should come off easyly ;)
PostPosted: Fri Sep 26, 2008 7:12 pm
Drives: MK3 Fiesta
Yeah if it removes the shine you can always T-Cut it, gives it that nice finish. Just MIND THE PAINT! You don't want to end up scratching it or anything, that's the LAST thing you want! L.O.L.
PostPosted: Fri Oct 03, 2008 7:28 pm
tried all the suggestion and none worked so rubbed it down so it was close to bodywork and stuck new badge over the top can only see it if you look really close, so not to bothered
PostPosted: Fri Oct 03, 2008 8:54 pm
IPA gets everything off. surprised that didnt work
PostPosted: Fri Oct 03, 2008 9:37 pm
meths?
WD40?
T-cut?
Eectrical contact cleaner from halfords?
PostPosted: Sat Oct 04, 2008 2:09 pm
yes tried everything
just didnt work
