It is currently Sat Sep 22, 2018 1:12 am
 Post subject: Fiesta Si 2.0
PostPosted: Mon Jul 11, 2011 9:27 pm
For sale is my Fiesta Si 2.0 track/sprint car.It only gets used once a month at a local sprint event I do.
The spec of the car is as follows.
ENGINE:2.0 zetec silvertop taken from a mk1 mondeo.Engine was on 128,000 when I put it in and it had a new cambelt kit before it was put in.It has only done aprox 200 miles since.It has a complete RS1800 inlet manifold,2.0 maf and 2.0 ecu.Engine runs fine,no smoke and pulls well.Also has a custom intake pipe with cold air feed from passenger headlight.I have also made some diy solid engine mounts.Battery has been relocated to the boot.Exhaust is a Ashley cat back system.The cat has also been hollowed out.10" slimline fan.
GEARBOX:The gearbox and clutch are still the standard items from the Si.
BRAKES & SUSPENSION:The front brakes are 280mm discs and calipers from a escort cosworth.The discs are drilled and grooved.Rear brakes are standard drums.Hel stainless brake lines are fitted front and rear.All the wheel studs are longer as I run spacers.It has Gaz coilovers which are in really good condition.The fronts were serviced just before I bought them and I had the rears done with new damping adjusters just after I bought them.It has polybushed lower arms which are not very old.The rear beam is also polybushed.It has a twin rear antiroll bar setup and both are polybushed.Has a Sparco rear strut brace.Also has a front strut brace but unsure of the make.
EXTERIOR:Wheels are sierra cosworth sharktooth 15" alloys with 195/50/15 Yokohama prada spec 2 tyres.XR2i skirts and arches,diy single wiper,bonnet pins,lightened quick release front bumper with laguna splitter,diy polycarb windows all round apart from drivers window as not done it yet.I have a slider kit to go with it for when the drivers window is done.De-wipered on the rear.
INTERIOR.dash has had the lower half cut away,ignition barrel removed and start button located on dash.Omp suede deep dish steering wheel,Cobra monaco pro bucket seat with side mounts and 3" 4 point harness.Battery mounted in alloy tray in boot.
Most probably few other things I forgot.Full build with loads of pics can be seen here. http://www.fiestaguides.co.uk/phpBB2/vi ... 50&start=0
The car does not have mot or tax as I never intended to use it on the road.I do have the V5 for it.
It is located in Bridgwater,Somerset.£1200 ono
 Post subject: Re: Fiesta Si 2.0
PostPosted: Mon Jul 11, 2011 9:35 pm
See if this link works instead.
http://www.rallyesportford.com/forum/vi ... f=32&t=828
PostPosted: Wed Jul 13, 2011 9:10 pm
Bump.
PostPosted: Mon Jul 18, 2011 6:56 pm
Offers?
PostPosted: Mon Jul 18, 2011 9:38 pm
Drives: mondeo st tdci
would you e concider selling/px'ing the wheels ?
PostPosted: Mon Jul 18, 2011 9:42 pm
If it aint sold in the next week I will break it so all parts will be for sale.
PostPosted: Mon Jul 18, 2011 10:04 pm
if you do break
how much roughly would you be wanting for them ?
PostPosted: Tue Jul 19, 2011 5:29 pm
big g1985 wrote:
if you do break
With the tyres,which are still good £200.
PostPosted: Wed Jul 20, 2011 8:13 pm
Can mods close as it's now being broken.
