It is currently Sat Jul 21, 2018 8:59 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 47 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Feb 16, 2012 7:32 pm
Drives: Suzuki Ignis Sport
nice work dude.
PostPosted: Thu Feb 16, 2012 8:44 pm
thanks homie
PostPosted: Thu Feb 16, 2012 9:32 pm
will be going on stand at singleton classic car show in may with steve my old man's mate, who is allowing the mk1 capri to be sprayed in his bigger garage
he owns this:
note the 3 spoke leather wheel, Fiesta RS turbo recaros and nice RS mats
and nice update on the mk1 itself!
sprayed in New forest Green (he believes, was old pot found in the stores)
fully laquered, 5 coats, needs to harden over the next 3 days and then will be flatted back and buffed
bonnet is in primer waiting satin black paint
let me know what you think, ill get decent pics with the camera once its out the garage!
PostPosted: Thu Feb 16, 2012 9:55 pm
more work done tonight on the mk3
all valves are in and springs on
lapping valves like a boss, with fast ford mag!
2 new exhaust valves
crowns de-coked, block mating surface cleaned
was fun trying to get pistons to TDC turning the key :lol:
all valves in
just the followers left now, spare valves...
tomorrow it should be put back on the block, just tappets a few gaskets, thermostat housing and head bolts left
considering stripping the carburettor down, as they need annual maintenance its likely due, and i have new seals and gaskets for it
comments welcome!
more tomorrow :)
PostPosted: Sat Feb 18, 2012 6:39 pm
Update
got each of the tappets fitted and adjusted to 0.025mm gap on the exhaust, 0.020mm on the inlet
fitting the thermostat
cleaned the bolts up
fitted the head and gasket, the 10 bolts in place ready for torquing sequence
cam cover gasket
cam cover mucky old bolts...
... were given a new lease of life
fitted
new exhaust gaskets
on... new air ratchet makes such light work of nuts and bolts :) and will set them all to 50lbs/ft too
inlet gasket... notice the water inlet pipe between port 2 and 3?
in my mind its bad design to have water flowing so close to the inlet ports, if a leak happened it could destroy con rods letting water int he chambers
done for last night, got in at 1AM!
these arrived today, handy quick air line couplings
timed up and all together minus the air box
slight snag, i dont have a clue about distributors, nor how to time them up
im getting spark, but i dont know if its firing at the right time.. doesnt help that the dizzy is loose and turns by hand!
can any one give advice?
i know its fueling, plus ive been pouring petrol down the carb, only managed 1 hickup from it :(
PostPosted: Sun Feb 19, 2012 2:55 am
need to get myself a strobe timing light to get the ignition timed up right, so if i cant borrow one, will buy one in the week
PostPosted: Mon Feb 20, 2012 11:47 pm
ordered a few bits
Powerspark ignition stroke timing light
and
Powerspark pointless electronic ignition kit
the electronic ignition kit is a great piece of kit, my fathers mk1 has it on the 1.6 pinto, basicly takes away the moving trigger arm which needs regapping and wears over time, these use magnets instead
car starts first time everytime and produces a better stronger spark!
Users browsing this forum: Bing [Bot] and 24 guests
