It is currently Sun Sep 23, 2018 4:18 am
Post new topic Reply to topic  [ 71 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Wed Jun 02, 2010 11:38 pm
Drives: BMW E90 330D M Sport
I thought i see a reverse camera in your rear bumper and i was right :thumbsup:
PostPosted: Thu Jun 03, 2010 6:40 pm
Drives: bmw r50 chilli red mini c
This weekend busy time for me and my car .
jobs
1) Painting Brake Calipers and hubs
2) Replacing rear Q lights both side new glass .
3) sorting dash lights and dials out checking connections or if any wires making contact with earth as fuse did blow .
4) center console refit
5) speed o cable refit
6) Clean up all earth under the bonnet
7) Rear wing to sort rust and fill and paint .also a round car and sunroof
8) festa si.com stickers to fit :)
9) some painting to do under car also re check rust
10) full side stickers to put on last thing
i had this car for 6 years way i look at it some people may not like the sitickers and stuff but because i am almost at the big 50 its sort of re living my youth :)
i expect i will remove it all in like a month or 2 :)
PostPosted: Thu Jun 03, 2010 7:05 pm
My rust Protection
Rustisol is unique:
This is the only rust protection currently available with a pH of 7 which can be directly applied to rust and which also combines with existing rust to form a permanent protective layer or coating.
Rustisol rather than being a rust converter is a completely original combination of active substances which make it fundamentally different from all acid based rust converters. Whereas the usual rust converters contain acids of strengths ranging from 0.5 to 3.2 Rustisol is completely neutral at a pH of 7 and combines with the rust to produce a ferro-organic-acid-free coating which gives complete protection against further corrosion.
Rustisol is the only protection against corrosion available with a pH of 7
Patents have already been awarded in the USA, Japan, Great Britain, France, Switzerland and Germany. Further patents are in progress. The German Patent Office recognizes that "technically, Rustisol is a major improvement on all acid-based rust converters".
Rustisol is applied directly to the rust:
http://www.metaflux.com/products_singles_70_35.htm
Alu-zinc Metaflux Liquid-Aluminium
70-41 Alu-zinc mixture anti-corrosion coating for larger areas, can be sprayed on or applied with a brush.
Then a wait then i spray Red oxide primer then after this i spray a paint spray over then to complete i under seal the area then i nomal wax oil like drainage holes or inside wings ETC
PostPosted: Sat Jun 05, 2010 11:00 pm
Drives: Fiesta si + the Van
hang on did i read that right your knocking on the door of 50,
nice one for going back to your roots
:thumbsup:
PostPosted: Sat Jun 05, 2010 11:15 pm
respect to that man :D :thumbsup:
PostPosted: Sun Jun 06, 2010 7:05 am
yes :(
But still very much in to doing stuff like this i do go to a lot of lan partys as gaming was a big part of my life for years ...
PostPosted: Sun Jun 13, 2010 9:37 am
I am also thinking of getting some panel woirk painting stuff like that done
I have some rust starting a round the sunroof and need some plating a round the ns rear Q panel also rust on the osr wheel arch so i have a friend who is a very good panel beater also have some one who would spray it so i am thinking after the summer getting work done on the car ..
i got this car like end of 2004 so i had it a few years last 3 years it pass with no problems at all so time for me to look under the car again .. i
PostPosted: Sat Jun 19, 2010 8:25 pm
Here is my ICE
I got this gem from a place in guildford because it was 4 years old and hads never been in a car was 117.50
tweeters
full range doors
shelf
http://www.pioneer.co.uk/uk/products/ar ... index.html
Sub
Amp
the stuff a bit old now but still sounds good but it setup for hardcore drum & bass and rap
P.S car needs a clean :)
PostPosted: Sat Jun 19, 2010 10:40 pm
Drives: mk3 Java, Fiesta RST
setup looks nice :thumbsup:
that headunit was a steal :shock:
RIP ANDREW STOW 1989 - 2009
RIP "JAM" 1984 - 2012
Dave G fsi wrote:
PostPosted: Sun Jun 20, 2010 9:25 am
love the headunit. all the sysem looks cool. bet it sounds nice.
PostPosted: Sun Jun 20, 2010 11:00 am
yes sounds good just by changing the head set its made a difference and the last one was a good one too
PostPosted: Sun Jul 04, 2010 9:35 pm
I have decided that i don't like the stickers any more so in about 6 weeks they will be coming off as i am having the last bit of welding done :) doing patch over the osr arch also welding in a new arch nsr + filling and also bonnet dent and sorting rust out on sunroof .. i am also thinking of getting rid of m3 mirrors and spraying the old mirrors to match the paint work ..
PostPosted: Sun Jul 04, 2010 9:41 pm
Drives: Fiesta Shed mk6
Plans sound good matey :thumbsup:
FACT wrote:
PostPosted: Sun Jul 04, 2010 10:22 pm
Drives: 1.1 106
sound good mate
PostPosted: Sun Jul 04, 2010 10:25 pm
Drives: tb'ed xr2.0
i like the plans for the colour coded wing mirrors
To rebuild?
PostPosted: Sun Jul 04, 2010 11:02 pm
Drives: Like a boss
will all add to it mate, will look really good when done!!
PostPosted: Mon Jul 05, 2010 9:21 am
Drives: Fiesta ZS
Set of standard/tinted/clear rear lights and you'd be on your way to a tidy Si! Sounds good.
PostPosted: Mon Jul 05, 2010 7:18 pm
also getting a dent sorted on the bonnet too
PostPosted: Wed Jul 28, 2010 10:21 pm
I have in the last few days order some bits to make my own (K&N 57i Air Induction Kits) as i don't like the look i am going to use the standed box that connect to the efi inlet but i have had it painted as i am going for a red look for the kit here some pictures just some bits i order..
This been painted to day
silicone hose
this may not get used yes not shure
more pictures to come i am hoping its done for the weekend
i have a air cone 84 mm and a oil breather filter also some joiners and a 45% red silcone pipe
also got some rubber bushs for the maf also making a bracket to carry the air filter should be more pictures later ..waiting on the post :)
PostPosted: Wed Jul 28, 2010 10:31 pm
Drives: 1.1 106
looks good mate
