It is currently Wed Sep 19, 2018 8:41 am
Post new topic Reply to topic  [ 474 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22, 23, 24  Next
PostPosted: Tue Feb 22, 2011 9:54 pm
Im going to make you feel bad and tell you my si was sat for about 3 months before i moved it, and it run sweet as a nut when I started it up lol
PostPosted: Tue Feb 22, 2011 10:00 pm
Drives: Si 1.6 & ST170
Tiababy wrote:
my 2.0 was like this when I picked it up.
Changed the oil and put an old intake on it (as the one on it was split) also cleaned up the MAF it helped it run better. I still get it every 3/4 runs but not all the time and it never gets to the stage where it stalls now. I'm pretty sure mine is down to having an intake that doesn't fit the MAF :lol:
Keep it up you'll get it there eventually (also its a lovely little si :) )
Thankyou, im gonna give it abit of a service and connect the maf sensor up some how and see how it goes, it was running decent before the battery went funny so its probably like me and not like being woke up lol.
The Loumiester wrote:
PostPosted: Tue Feb 22, 2011 10:07 pm
Drives: Mk1 FRS and FRST
:lol: :lolz:
Takes me a good couple of hours to wake up too, put some very strong black coffee in the fuel tank :thumbsup: :lol:
Good luck getting it sorted anyway mate :)
PostPosted: Tue Feb 22, 2011 10:12 pm
Drives: 2004 Volvo S60 D5
I remember when i got my new battery my engine ran like sh?t when it started after the battery was fitted.
I just revved it a bit until it stayed running and then left it for like 10 mins for the ECU to learn the engine.
As it was used to low power and reset itself once the old batt was disconnected
PostPosted: Tue Feb 22, 2011 10:17 pm
Dont know they did that, maybe thats a cause of its strange accelerating.
PostPosted: Tue Feb 22, 2011 10:28 pm
Yeah if your ECU has no power going to it for like 5 mins it resets itself and forgets everything. So then you have to let it learn the engine afterwards so it can run smoothly. Try resetting your ECU again
PostPosted: Tue Feb 22, 2011 10:50 pm
Will do, so I just disconnect the battery again to do it?
PostPosted: Tue Feb 22, 2011 11:57 pm
Yupp
PostPosted: Wed Feb 23, 2011 11:45 am
i left my si for a year and it started first time with a decent battery sounded lovely too even with kkdead headgasket lol
PostPosted: Wed Feb 23, 2011 12:05 pm
Drives: fez 2.0 +1.3
im going to make u feel bad my si has been off the road for over 2 years and has sat for periods of 6months or more but with fresh fuel and battery she goes first time every time :thumbsup:
PostPosted: Wed Feb 23, 2011 5:08 pm
I finished work early today and did a quick make shift job on connecting the wires back up on the MAF.I started it and its running great now, must of been that combined with being stood for ages, i reckon it could still do with a service but good stuff!!
It quite smokey on the back though but other than that running good.
Hopefully when mounts are on i should have my car back . . . although i still have a problem with it wobbling when i turn at speed., any ideas? CV joints should be ok so god knows lol
PostPosted: Wed Feb 23, 2011 7:56 pm
track rod ends? a complete guess btw ;) just wanted to sound clever :teehheee:
PostPosted: Wed Feb 23, 2011 9:25 pm
Lower arms? Steering rack wear or air in the system? Universal joint on the steering rack fooked? track rod ends?
Theres a list to keep you busy :thumbsup: :lol:
Glad its running ok again mate :thumbsup:
PostPosted: Wed Feb 23, 2011 9:56 pm
just got in from driving it and its running well!
How would i check these items?
cheers guys.
PostPosted: Wed Feb 23, 2011 11:37 pm
woo got it right :D cheers dave ;)
PostPosted: Thu Feb 24, 2011 12:19 am
Smart arse lol.
PostPosted: Thu Feb 24, 2011 12:45 am
Drives: 2.0 fiesta si + mk3 1.1
check the bushes and shiz to see if there worn
replace with polybushes
Fiesta Si 2.0
Fiesta 1.1
Peugeot 206 sw 1.4
PostPosted: Thu Feb 24, 2011 9:44 am
PostPosted: Sat Feb 26, 2011 8:59 pm
Put the Vibra-technic gearbox mounts on and think i fucked it up as expected from a novice because i started the car once i put them on and i could feel the engine all through the car, its like the engine had no movement at all. It was pretty hard to get the gearbox bearer back on. Any help would be appreciated in how to adjust it or what to check?
PostPosted: Sun Feb 27, 2011 4:48 pm
Thats what you expect from vibratechnic mounts. They are just as good as sticking a plate of metal in there, they are that solid lol
Users browsing this forum: Google [Bot] and 14 guests
