Fiesta-Si.com • View topic - My SI; 2.0 Blacktop - Crashed it... :(
It is currently Sat Mar 28, 2026 6:24 pm
Post new topic Reply to topic  [ 148 posts ]  Go to page 1, 2, 3, 4, 5 ... 8  Next
PostPosted: Mon Mar 02, 2009 7:49 pm
3rd time lucky; hopefully wont get crashed into this time/get loads of dents/i wont slip on wet grass and dent the rear 1/4 etc lol
-scorpion full exhaust system, but swapping to my magnex system/decat.
Allready fitted my:
-avo coilovers with powerflex top mounts
-adjustable wishbones with powerflex bushes
-turbo windows
Plans are to fit RS Accessory bumpers and and RS arches/sideskirts, Zetec S rear beam and brakes, 2.0 Engine and im getting my recaros steam cleaned ready to go back in.
Needs alloys, anyone selling some 14'' ford wheels? fiesta/escort SI?
Comments/criticism welcome. :)
PostPosted: Mon Mar 02, 2009 7:51 pm
wow, thats a good find already has all the expensive bits done :thumbsup:
PostPosted: Mon Mar 02, 2009 7:53 pm
PostPosted: Tue Mar 03, 2009 7:52 pm
i was gona buy this car not long ago, but freeky beat me 2 it! lol looks pretty minty thou mate! nice 1! :thumbsup:
PostPosted: Tue Mar 03, 2009 11:19 pm
looks nice and clean :thumbsup:
what happened to your other one?
PostPosted: Wed Mar 04, 2009 12:35 am
u say u are goin to swap scorpion for magnex...
well can i be cheeky and when u swap can i buy it its a good price ..... :thumbsup: :thumbsup: :thumbsup:
PostPosted: Wed Mar 04, 2009 3:41 pm
Nice :)
I want some coilys again :red:
PostPosted: Thu Mar 05, 2009 1:11 pm
My god that thread title could of been mine lol
Glad to see your getting on with it mate, shes a good base.
Built Not Bought
PostPosted: Fri Mar 06, 2009 2:02 am
looks good mate best of luck with this one 8-) :thumbsup:
PostPosted: Fri Mar 06, 2009 6:34 pm
Looks nice that does mate :thumbsup:
PostPosted: Sat Mar 07, 2009 3:33 am
looks nice 8-)
i want ur lights :chill:
RuLeThEbEnDs
PostPosted: Sun Apr 12, 2009 9:11 am
New wheels, Got these for £100 with brand new tyres. Not a mark on them! I wanted 45 on the profiles (there 50's) ideally but at that price im gnna use the tyres till there dead.
What do you think? Btw they are dark grey, not really dirty lol.
 Post subject: Re: My SI; New wheels
PostPosted: Sun Apr 12, 2009 9:53 am
she look's clean m8 and score for the rims to good find m8 :thumbsup:
PostPosted: Sun Apr 12, 2009 12:28 pm
nice wheels mate. if you ever want to sell them im here :lol: :thumbsup:
PostPosted: Mon Apr 13, 2009 9:56 am
Really like the new wheels mate :thumbsup:
PostPosted: Mon May 11, 2009 12:13 pm
You taking this to f.i.t.p. I wouldnt mind seeing it again lol
Built Not Bought
PostPosted: Sun Jul 26, 2009 11:07 pm
Trust me, i killed the 1.6, so time to build my 2.0 blacktop from a focus!
Little bit of modding required on the mounts will explain in pics.
Cleaned bare block. Lightly honed and ready too go
New ACL bearings
Make sure you thoughroly (SP) clean every thing, i almost left this trace of old bearing in the cap.
New bearings in caps
Rear Mounting bracket, had to be drilled out and can only accept 2 bolts. I am working on a better fix!
Clean crank
Crank in block
Caps on and torqued up.
New rings
Pistons going in
Hard to see in photo but the is a number on it, 2 i think. Number 2 means cylinder 2, (1,3,4 respectively) this number is only on one side on conrod and cap, and goes closest to the front of the block.
Pistons in!
Oil pump and new crank seal
MLS Victor Rienze head gasket. OE fitted to VAG so should be good
Water pump inlet, totally different to zetec.
Waterpump housing
Water Pump seal. IIRC this was quite expensive! bout £8!
And shes on!
This is a zetec non PAS alternator/engine mounting bracket. Its hard to tell, but alot has had to come of it to make it fit. It majorly fouled the water pump housing. See next pic.
Looks tight?
It bloody dam is!
Lots had to come of the clear the housing here too.
Breather and new gasket
And shes on.
More will come as this is as far as ive got.
Had an issue with the silvertop sump in that you can't fit the oil baffle plate. It attaches via the maincap bolts. I thought this wont be a problem as il just use four bolts from the silvertop caps. How ever due to the design in the blacktop sump, the blacktop main caps are very short and the bolts from the silvertop is too long. I PMed DALSY, and he said hes used the silvertop sump with no baffle, however i feel that it should be there. So im using the blacktop sump (which i must admit has a much better baffle and is 2 piece)
This has had to be modded. Will post up pics. It fouls the driveshaft and theres no room for starter, so alot has had to be grinded off. (not as bad as what it sounds!)
PostPosted: Mon Jul 27, 2009 12:03 am
Doing well there mate, keep up the good work 8-)
PostPosted: Mon Jul 27, 2009 2:46 pm
i'm looking to fit the 2.0 blacktop in my fiesta si, as the blew the rs1800 engine up, and the escort gti engine i replaced it with just isnt great, even with the 130spec cams and ecu,
apparently you can get the port for the water pump opened up at a machinists and have the correct holes drilled and tapped to fit the zetec silvertop waterpump then use the silvertop zetec camblet setup and single tensioner pulley(wit idler pulleies bolted to the water pump)
do you know if the silvertop cylinder head will fit the blacktop bottom end?
does the silver top pick-up pipe fit in the black top with silvertop fiesta sump?
buttery biscuit boost
PostPosted: Mon Jul 27, 2009 5:56 pm
Users browsing this forum: Google [Bot] and 58 guests
