It is currently Mon Jul 16, 2018 1:36 pm
Post new topic Reply to topic  [ 266 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 14  Next
PostPosted: Sun Jun 14, 2009 8:14 pm
Drives: 2litre Si
as you say left the braking a tad to late once and bottled it :doh: that was the early sessions when still had the Toyo road tyres on, it will now rev to just under the red line in 5th by the end of the straight which is perfect at about 125mph and as good as a friends early elise,
With the new tyres on as the last session once they warmed up were incrediable especially the bomb hole and coram's 100% improvement than road tyres, and still ok when rain first started.
Cant wait wait for the next one now :thumbsup:
PostPosted: Tue Jun 16, 2009 12:18 pm
Drives: 2009 Golf 2.0 GT TDI
125 is about perfect for that circuit and still gives a short enough gear box for the twisty stuff.
If you go on another track day let me know and if I'm not in London I'll come and take a look.
Tied
PostPosted: Wed Aug 05, 2009 11:32 am
Drives: 2litre Si
done another trackday yesterday, was great fun ran great all day only couple of issues found a crack in the plastic thermostat housing which started to leak, lost a alloy wheel center cap and most of all need more POWER!!!
got a vid of hassling BMW's, RS500, ect (must admit the RS500 was imaculate and wanted to get out of the way of me!!)
Need more power as shown by mates rapid 206bhp Clio following me but it was nice to see my engine looks good with no smoke.
So thinking of over winter job (if passes MoT next week), ported head,cams and ECU so anyone got anything going cheep??
PostPosted: Wed Aug 05, 2009 11:58 am
Drives: BMW E90 330D M Sport
Love the vid man, nice driving...looked like you was having fun :thumbsup:
PostPosted: Fri Aug 07, 2009 10:51 pm
Good video, nice to see its running well, and scaring some bigger machinery :thumbsup:
Tied
PostPosted: Sat Aug 08, 2009 12:07 am
Drives: Fiesta si + the Van
did you manage to sort the wetting of the plenum chamber/ air box if not coat it in wood glue or pva glue
PostPosted: Sat Aug 08, 2009 8:55 am
Drives: 2litre Si
the plenum is ok, its wetting of the air filter which is the problem, thinking of fitting a sealed viper type filter canister with a cold air field as where the filter is currently had a inlet temperature of about +5 degree above ambiant.
PostPosted: Sat Aug 08, 2009 1:03 pm
Drives: MK1 Focus Estate Ghia
I say lose the plenum. Fit some better injectors. Headwork, Cams, Mappable ECU. Should see you more power :thumbsup:
Lose some more weight if possible (on the car I mean :lol:)
PostPosted: Sat Aug 08, 2009 5:40 pm
Drives: 2litre Si
if it passes the MoT next week all the above is on the winter shopping list, its running 2litre injectors at mo with orignal sandwich plate, hoping for 180bhp does anyone know what the maximum flow/power of the 2litre injectors is? or wether will need to change to end feed and bid the sandwich plate?
PostPosted: Sat Aug 08, 2009 6:51 pm
Think the 2.0ltr ones are near your max at the moment tbh
I think I worked out the RS2000 injectors max to around 190bhp, and they fit straight into the zetec sandwich plate ;)
But if your going to use bigger injectors surely the throttle bodies have their own injector holes in them?
PostPosted: Sat Aug 08, 2009 6:55 pm
Drives: Suzuki Ignis Sport
Havent looked at this thread before. nice lil track beast u got there mate. :thumbsup:
sounds lovely. wa exhaust u running?
and what clio is in the vid? its a bit of a beast. lol
PostPosted: Sat Aug 08, 2009 9:17 pm
Drives: 2litre Si
the GSXR600 throttle bodies using at mo have the injectors blanked off, but ive got a set of larger GSXR750 42mm to fit but didnt want the hassle of respacing the fuel rail if other options.
exhaust is a Ashley 4-2-1 manifold and a 2 1/2 stainless single box system which is a bit noisy at 102Dba but sounds crisp.
The clio is a 182 totally stripped, race clio cup suspension, with cams, throttle bodies and emerald ECU running 206bhp and
can keep up with most things.
PostPosted: Sun Aug 09, 2009 11:20 am
Sounds lovely mate, im supposed to getting an ashley full system with a mani.
that clio seems to be a bit of an animal lol
PostPosted: Tue Aug 18, 2009 11:24 am
Drives: 318 ci
nice work mate just not sure im picking this up right :? you are running bike bodies with the standard ecu wiring etc if im right how is this done any help would be appreciated top work and nice videos
PostPosted: Tue Aug 18, 2009 4:31 pm
Yes he is.
By keeping the injectors in the sandwich plate, he has linked up the bodies and made an airbox to go ontop of them. Thus keeping the maf on the end of it, so you can run them with the ecu etc.
PostPosted: Wed Aug 19, 2009 11:41 am
Drives: 318 ci
cool mate just dont see the benifit of this over carbs seems like a lot of hassle for the same gains roughly or is there something im missing out on :thumbsup:
PostPosted: Wed Aug 19, 2009 1:41 pm
Drives: 2litre Si
i was going motorbike carb route as have done it before and produced good power on a tuned CVH. However my thoughts were, carbs on the Si were easy part to fit, but as mine is MoT'ed then thought carbs are not ment to work well with CAT's (only refitted for MoT) due to higher emissions leading to failure. plus would have to change fuel pump or additional pressure regulators and also need to fit some sort of spark only ECU. ( i got a 2D ignition only webcon ECU) so went for injection and using the Standard ECU was a easier option.
But as im using the MAF/ECU there is a restriction topping @150bhp and as you are no doubt thinking, carbs will potentially produce more power at about 160bhp. but as im looking at more engine work this year im sticking with injection and replacement mapable ECU.
but finally if it was a track only car with no MOT I would have stuck motorbike carbs on it :thumbsup:
PostPosted: Wed Aug 19, 2009 3:38 pm
Drives: 318 ci
cool mate once you get aftermarket ecu and a set of cams should see you knocking on the door of 180 -200.mines does get mot'd but my mate does it so emmissions dont matter :halo:
PostPosted: Sat Oct 03, 2009 6:29 pm
Drives: 2litre Si
done another trackday today at RAF Marham, it was a great day had one big tank slapper moment at 100mph+ resulting in me shouting i can save it 5 times before spinning but forgot to start the video camera! Fiesta ran fine all day hitting a sat nav verified 132mph down the straight :thumbsup: got some video fottage will upload tomorrow
PostPosted: Sat Oct 03, 2009 6:52 pm
Drives: Mk1 FRS and FRST
Awesome, nice one mate! 8-)
Can't wait to see the footage :chill:
