It is currently Mon Jun 18, 2018 10:55 am
 Post subject: exhaust problems
PostPosted: Sun May 22, 2005 6:35 pm
Drives: Shitroen VTS
hi, my 1.6 has a hammered cat, the ride hight has been lowered 35mm, my exhaust shouldnt be scrapping should it? dumb question i know but i dont want to get it replaced for it to happen again!
speed bumps and single lanes have become a nightmare! the cat hangs the lowest roughly 2.5 inches off the ground!
cheers! :P
PostPosted: Sun May 22, 2005 7:51 pm
there should be a crossmember under the cat that keeps it up where it should be
PostPosted: Sun May 22, 2005 8:03 pm
Drives: Fiesta si + the Van
are u sure its not the centre pipe nearly on the floor if it is then get under the car(u might need two ppl) push the centre pipe up then tighten the exhaust clamp(cat to centre pipe) and bobs ur uncle exhaust is of the ground :D :D
