It is currently Sun Jul 22, 2018 7:50 am
 Post subject: Clutch?
PostPosted: Fri May 20, 2005 3:37 pm
i noticed it yesterday, when i changed gear and i am liftin my foot off the clutch when it returns 2 it normal position it makes a clickin noise :? :?
i dont think its the clutch itself! well i hope not!
can any1 shed any light on the matter!
PostPosted: Fri May 20, 2005 6:47 pm
no help here but mine does the same, i think its probably just a loose bolt or something on the clutch pedal lever have a look under when you press it (by hand) see if you can see anything wobble about that shouldnt :)
i'll have a look tomorow..
nothing to worry about i shouldnt think though (have you ever driven any diesel engined car before 1998?)
PostPosted: Fri May 20, 2005 8:24 pm
just to add a bit of none help to add to this thread mine is wank my clutch it hates going in first and it hates reverse i sometimes have to press my cluth in three or four times before it will actually go in first!!!
PostPosted: Fri May 20, 2005 9:28 pm
Drives: Fiesta si + the Van
it could b the self adjuster on the pedal or the cable isnt rooted properly or its the arm ov the pedal moving with catches on the self adjuster thats if the noise is coming from the inside ov the car hope this helps :)
 Post subject: Re: Clutch?
PostPosted: Fri May 20, 2005 9:39 pm
spot on its time for a new rachet mechanism ?10 from ford i think a real nightmare to fit though
PostPosted: Fri May 20, 2005 9:43 pm
good to b ov service just hope onslack
can get at all the bolts to get it of, thats if its not the one with the braket over it :)
PostPosted: Sat May 21, 2005 9:16 am
cheers for all the help guys! gonna get it checked out hopefully 2moro!
cheers again
PostPosted: Sat May 21, 2005 1:08 pm
Drives: 170bhp RS
depends how often it does it. once or twice a week will be your clutch adjuster. if its more often, id suspect that the adjuster has either knackered or its at full whack and it trying to adjust further when it cant.
mine did it loads when my clutch was shagged, but i do mean shagged. ask des! :lol:
PostPosted: Sun May 22, 2005 9:25 am
well i found our what was wrong, the hard way! went down town 2 have a look at a monkey bike! start the2 sec journey home and my clutch cable snapped! :cry: hopefully gonna get it repaired 2day! will keep u informed!
PostPosted: Sun May 22, 2005 5:20 pm
all is well went 2 get a new clutch cable and fitted it myself with the help of my girlfriends dad( top bloke) so my fez is bak on the road! 8-)
PostPosted: Sun May 22, 2005 5:26 pm
ouch :shock:
will have to keep my eye out on this then
PostPosted: Sun May 22, 2005 11:35 pm
Drives: Nissan Pulsar GTi-R
Clutch cable is such a common thing for the Si :rolleyes: Mines ate its way through 2 in 6months.
Im going to get a spare one and keep it in my boot, so Im not stranded anywhere :lol:
PostPosted: Mon May 23, 2005 11:03 am
Drives: 170bhp RS
damn it, i was wrong :x AND i was gonna mention that the cable could've stretched meaning its trying to adjust and it cant. nevermind.
least its not a big problem, you can still get it home with ease :)
PostPosted: Mon May 23, 2005 9:44 pm
calm down its only a comercial, kill that michael :devil: :devil:
PostPosted: Thu May 26, 2005 5:18 pm
i did have some pics but there r 2 big i will post them up when i resize them and get back from spain
Users browsing this forum: Bing [Bot] and 10 guests
