It is currently Thu Jan 17, 2019 3:46 pm
 Post subject: 1.3 CFI Zetec conversion
PostPosted: Thu Sep 24, 2015 8:29 am
Im really sorry if im asking questions which have been answered already, I have searched through the site and Google and cant quite find what im after!
I recently got given a low mileage solid MK3 Fez its the 1.3 HCS (which definitely doesn't stand for "High Compression Sport")
I want to have a bit of fun with it and drop a 2.0 silvertop in but leave it looking completely standard (apart from some wider steel wheels and obviously some bigger brakes.
I know this is a tried and tested conversion so ive been doing research but still have a couple of questions...
Is it worth it?! How do they go with a 2.0 lump in, i take it the fact they weigh very little helps!?
Can i retain my gearbox for shorter ratios, if so what clutch/flywheel set up do i need?
Do i need to change the fuel tank or lines?
Any help would be apperiated
PostPosted: Tue Mar 15, 2016 5:56 pm
id say it's definitely worth it. Only been in one standard 2.0l si and i couldnt believe how torquey it was.
couldnt answer on the others bits, but i'm sure someone will help you there!
You'd need a zetec flywheel and clutch, but im not sure how compatible they are with your gearbox. Any ideas which box the 1.3 has?
is it fuel injected?
PostPosted: Tue Mar 22, 2016 12:45 am
Drives: C2 VTS
In short you need many parts of the 1.6 zetec fiesta.
You can keep the gearbox.
Is it worth it, hell yeah! I miss mine so much.
PostPosted: Sun Oct 09, 2016 2:28 pm
Wow this was a year ago!
Few bits have changed on the car, it managed a charity rally to Germany and back, a weekend in north wales and a trip to Amsterdam. Ive had fun in it so nows time for the conversion, ive had zero spare cash of late due to paying for a weddin which by the way are DAMN expensive :shock:
I still want to go down the rat rod/sleeper look so heres what she currently looks like....
I also cant get my head around why there is no rust, which to be honest is part of the reason im bothering, a rot free shell is deffinetly hard to find!
So once again any help with what i need to go 2.0 would be great! :wack:
