It is currently Sun Jan 20, 2019 8:19 pm
PostPosted: Mon Jun 22, 2015 9:15 pm
So I have a Fiesta '94 Mk3 and i'm having trouble with rust on the bottom, how can i resolve this.
Also i have an oil leak but i'm not sure if it's coming from the oil reservoir or from the engine itself :/ . any tips on how to check this and resolve the problem?
PostPosted: Mon Aug 03, 2015 3:59 pm
Drives: mondeo st tdci
best way to sort rust is to cut it out and weld in fresh metal
the oil leak
clean the area up then run the car you should then be able to see where its coming from
PostPosted: Mon Aug 03, 2015 6:34 pm
Drives: 2litre Si
Surface rust or rot and MOT failure? Of inner cils and chassis? It can get extensive/expensive when you start digging with a screwdriver any photos from underneath, lots of photos in my track car build
