It is currently Tue Jul 17, 2018 4:48 pm
PostPosted: Thu May 29, 2014 7:34 am
Hi guys,
My fuel pump has gone a bit temperamental, and I've diagnosed the fault as either the pump dying out due to age and usage or the wires on the plug - resistance on the wires on the plug show no breaks according to the multimeter, well at the plug end, I still need to check the rest of the loom though.
My main question is that if the pump is at fault (will confirm when removed and tested), do any others from any other ford models fit as a standard replacement item with the same fuel connections and pressure that the pump provides?
I've been looking around the internet for zetec pumps but cannot see anything for sale as of yet - especially for a zetec model. They seem to be quite rare :(
PostPosted: Fri Jun 13, 2014 9:28 pm
Drives: 2.0 fiesta azura
Mate of mine done a 2liter conversion to a 1.1 and used the 1.1 tank anf fuel pump and had no problems.when i done my conversion i changed the fuel pump just to be on the safe side but the serial and manifactures numbers where both the same
blunty
