It is currently Mon Jun 25, 2018 6:59 pm
 Post subject: Mk3.5 Cradle?
PostPosted: Tue Mar 18, 2014 11:15 pm
Drives: Fiesta Mk3
Hey does anyone know if the gearbox cradle is the same on a mk3.5 1.1 to a fiesta 1.6? If so any ideas why I was having trouble getting it to fit?
Only advice I've been given is to change the gearbox mounts? :doh:
 Post subject: Re: Mk3.5 Cradle?
PostPosted: Wed Mar 19, 2014 4:10 pm
Drives: Mk3 rs1800i
the cradles are the same on mk3 and mk3.5. the mounts only need to be changed if they are fucked because they are the same too. you just need to make sure the engine mount isn't tight to allow full movement and lift the engine and push it about until the bolts slot into the holes. then tighten it all up. just be brutal with it until it fits :thumbsup:
FORD COMMITMENT...FOR LIFE
QUOTE OF THE DAY 29/1/2013
bensouthport wrote:
get your finger out and fix the fucking thing! (if you reply with the same thing to me you can fuck yourself, yours is easier to fix than mine is)
QUOTE OF THE DAY 30/1/2013
Sam_RSi wrote:
i could build a car from scratch quicker than he has done his engine conversion
R.I.P Ben 'Jam' Elvin
PostPosted: Wed Mar 19, 2014 8:03 pm
I not agree. I did want to fit a 1.6 cradle onto a 1.8 , but it didn't fir for some stupid reason.
Thing was about 2 cm shorter than the 1.8.
PostPosted: Wed Mar 19, 2014 8:24 pm
Drives: Mk3 rs1800i
we aren't talking about it fitting the car. we are talking about the mounts fitting the cradle. they are the same :thumbsup:
PostPosted: Thu Mar 20, 2014 9:31 am
Drives: Fiesta Mk3
I shall let you know the outcome tonight
PostPosted: Thu Mar 20, 2014 6:56 pm
Whoehaha, sorry im dutch :p thought the cradle underneath the car
PostPosted: Mon Jun 16, 2014 12:51 pm
The gearbox cradle is different comparing it from a 1.1 to a 1.6 and the mounting brackets within the cradle are also completely different and the rubber mounts themselves are different as the si has larger rubber mounts and the 1.1/1.3 has little ones but they all fit each other when it comes to the rubber mountings but the 1.1 ones are not as strong, same with the cradles the zetec and cvh ones are thicker
