Fiesta-Si.com • View topic - silver top question
It is currently Sat May 25, 2019 7:54 pm
 Post subject: silver top question
PostPosted: Tue Mar 11, 2014 10:49 pm
Hiya, I have bought a 1800 silver top from an xr2i & have been told I can use a rs1800 or xr2i engine loom is this true & I have been told if I use a rs1800 ecu it will then have the 130 bap like the rs 1800's do is this true ?
 Post subject: Re: silver top question
PostPosted: Wed Mar 12, 2014 10:29 am
you could use any zetec loom/ecu to run the engine as long as the ecu matches and works on the loom you intend to use
i'm assuming this is going into a mk3 fez? if so id stick to the rs1800/xr2i zetec/16v si looms and ecu combo's
you'd need the cam's and the inlet from an rs1800 if you want to get near the 130 spec :thumbsup:
PostPosted: Mon Mar 17, 2014 1:14 am
PostPosted: Tue Mar 18, 2014 5:07 pm
All the same m8, and you mean a erst gearbox? Frst has no lsd and is the same as a 1800.
