It is currently Fri Apr 20, 2018 11:39 am
 Post subject: fuel pump issue
PostPosted: Mon Jan 13, 2014 9:43 pm
Drives: 2.0 fiesta azura
Right guys the fuel pump on the fezzy decides to stop working now and then.so today the fuel pump stopped again so i took out the relay and riged it so the pump stayed on constant.so i started the car and it ran normal.so i took the riged relay back out and put a normal relay back in and the fuel pump came back to normal any ideas on whats wrong
cheers blunty
blunty
 Post subject: Re: fuel pump issue
PostPosted: Mon Jan 13, 2014 9:59 pm
Check the crashsensor.. changed mine also,same problems.
Worked now and then
PostPosted: Mon Jan 13, 2014 11:26 pm
Cheers mate will try that
blunty
PostPosted: Mon Mar 03, 2014 8:45 pm
BUMP!!!!!!!! changed the crank sensor and fuel pump still the same problem :(
blunty
PostPosted: Tue Mar 04, 2014 12:34 pm
If removing and replacing the relay made it work then it sounds to me like a dodgy connection on the relay.
I would take it out and clean all contacts/check for broken wires around the relay.
Paul
PostPosted: Thu Mar 06, 2014 2:43 pm
After doing some testing the relsy aint always recieving igntion live any suggestions
blunty
PostPosted: Thu Mar 06, 2014 3:32 pm
Hi mate,
Standard no signal checks
1) Poor connection at relay
2) broken cable on run from relay to ignition
3) poor connection at ignition
Simple fix would be run a new cable with spades from relay to ignition switch (pretty sure you can pull ignition live from there!)
Paul
