It is currently Wed Apr 25, 2018 7:22 pm
 Post subject: one touch down windows
PostPosted: Sun Oct 27, 2013 10:18 am
Hi Guys,
A previous owner installed the one touch down relays on my car, both have messed up within the last 2 weeks :doh:
I want to put it back to standard and just have normal electric windows, any help would be appreciated :thumbsup:
Thanks
Liam
PostPosted: Sun Oct 27, 2013 10:50 am
Drives: Si 1.6 & ST170
Its just some relays (or whatever its called) needs removing, if you follow the wire from the switch you will see it.
But I shall be corrected by anyone whos fitted them as I havent, just seen whats needed online.
The Loumiester wrote:
PostPosted: Sun Oct 27, 2013 1:37 pm
As above, just remove the relays and re-wire back to standard. It should just be a case of snip and solder. But it all depends how the previous owner has wired them in, you might be able to get away with just unplugging the relay itself and it'll be back to standard, so try that first, if not, snip and solder :)
PostPosted: Sun Oct 27, 2013 3:38 pm
Thanks guys 8-)
Users browsing this forum: Baidu [Spider] and 6 guests
