It is currently Sat Sep 22, 2018 10:28 am
 Post subject: Fiesta fan heater
PostPosted: Sun Oct 20, 2013 4:43 pm
Hi I'm new to this forum and looking for help.
I have a Fiesta 1.2 on an 06 plate.
1 day the heater was working, the next it had packed up.
Swapped the fuse with one from the ABS, switched on the ignition, turned on the fan, heard a click but no luck with the fan.
Put the fuse back in the ABS slot and the ABS warning light is on.
So, the fan has blown the fuse. I can replace the ABS fuse but where to go from here?
I understand it could be the resistor but is there a way to narrow the problem down?
Thanks
Paul
 Post subject: Re: Fiesta fan heater
PostPosted: Sun Oct 20, 2013 6:36 pm
More than likely the resistor like you mentioned. The only way you can narrow down the problem is by getting another one and swapping it and see if that sorts the problem. If that isn't the problem then things like wiring - earths - will be the next thing to check.
PostPosted: Sun Oct 20, 2013 6:49 pm
Thanks Danny Boy, I'll try and get on it next weekend.
