It is currently Fri Sep 21, 2018 10:33 am
PostPosted: Fri Jul 05, 2013 10:17 am
Hi I'm looking at running carbs on my 2.0 fiesta xr2i, I have the inlet manifold, cbr600 carbs 1999, cbr fuel pump and esc module.
My question is.... Can I run esc on a set of carbs with TPS?
My inlet is setup for esc hose but will the carbs still work fine without the TPS plugged in?
PostPosted: Sun Jul 07, 2013 8:56 pm
Come on guys, would I be able to run a set of carbs with TPS on esc. I won't connect the TPS in but will it effect the running
PostPosted: Tue Jul 09, 2013 1:49 pm
Drives: 2litre Si
Are you connecting in the vacuum advance on the esc unit to your inlet manifold? Don't think esc unit has option of tps so no problems with not having it connected, without either will just have a 2D ignition map without any engine load adjustment
PostPosted: Tue Jul 09, 2013 2:42 pm
thank you for your reply.
i have a set of cbr600 carbs which have tps. i am going to use esc which means using vacuum hoses on all four pipes from the inlet.
will the tps on the carbs effect the carbs running on esc if it not plugged in?
i shouldnt think it would make any difference in the running if it left unpluged as it only used with ecu or megajolt right?
PostPosted: Tue Jul 09, 2013 2:55 pm
Drives: 2litre Si
Not connecting the carb tps will have no effect to the operation of the carbs or esc unit, just leave it disconnected.
Are you using the tappings on the carbs for vacuum on ecs? What about brake servo? What engine are you fitting carbs on? I have some zx6 carbs running on a 1.6 cvh
PostPosted: Tue Jul 09, 2013 11:26 pm
I have a 2.0 lump in my xr2i 16v. Emmions will fail mot but I can get around that. I will be running the esc off the inlet take offs. Thinking of using male valves in the injector holes from each port. Brake servo?
PostPosted: Sun Aug 18, 2013 12:38 pm
carburetters don't need a tps they have a fuel mixture screw which should be set on a rolling road and they were work of floats
