It is currently Sat Jul 21, 2018 1:25 am
 Post subject: headlights...?
PostPosted: Thu Jun 20, 2013 5:49 pm
the front headlights, not the big h4 bulb but the other one locates slighly lower thats very small (in same unit not the indicator one) what is this and when's it ment to come on? ta
TEAM AUBERGINE
 Post subject: Re: headlights...?
PostPosted: Thu Jun 20, 2013 6:04 pm
That's your side lights so should come on at the first position round on the stalk. Second position puts on dipped beam (big bulb) and then push stalk for main beam (also big bulb as its a double filament)
Paul
PostPosted: Thu Jun 20, 2013 6:30 pm
Paul
right....
mine ;
first pos: big bulb (not that bright)
second pos: big bulb (bright)
pull/ push : big bulb brighter.
little bulbs do nothing?!?!
TEAM AUBERGINE
PostPosted: Thu Jun 20, 2013 7:04 pm
Are you sure it's the big bulb that lights up and not the small bulb illuminating it?
Best thing to do is twist and pull out the small bulb and see what happens.
Sure what I put above is right though :/
PostPosted: Thu Jun 20, 2013 7:17 pm
Drives: Mk3 fiesta ghia
You ha the little ones, sidelights, but first click should be the big bulb, not bright, running lughts and they should only come on when the ignition is on, second click is headlights (h4) and push it forward is full beam (h4)
Helpful or??
PostPosted: Thu Jun 20, 2013 10:48 pm
cheers all now got it sorted! both little bulbs had crached at the same time!>!>!!? LOL not had that before!
TEAM AUBERGINE
