It is currently Tue Jul 17, 2018 3:19 am
PostPosted: Sun Jun 09, 2013 9:16 pm
Gents
Been checking over all of the front set up, suspension, wheels, driveshafts etc and hit a problem. i had the front jacked up with the wheels attached.
As i checked the near side wheel for play etc i noticed the driveshaft connecting to the offside cv boot was clonking as i turned it left and right.
So off i went to the other side to double check. Now it sounds to me as if its not seated properly. However im starting to think it might be because its missing its snap ring?
Does this sound correct?
In regards to the brake pads, does the outer side need a smearing of copper grease or is this not 100% necessary?
Thanks, Ben
PostPosted: Sun Jun 09, 2013 9:40 pm
Drives: mondeo st tdci
I would get a snap ring on it as it holds it all together.
I always put a smear of copper grease doesn't take any longer to do
PostPosted: Sun Jun 09, 2013 9:49 pm
Yeah im just hoping that it is missing the snap ring as i dont want to have to fork out for a new driveshaft!
Any ideas where i can get one? Ebay doesnt seem to be coming up trumps.
Ok bud ta
PostPosted: Sun Jun 09, 2013 10:04 pm
Just had a revelation, Im using and erst box with fiesta driveshafts. That works doesnt it?
PostPosted: Sun Jun 09, 2013 10:05 pm
ye they are the same fitment
ford or a gearbox specialist
PostPosted: Sun Jun 09, 2013 10:10 pm
ok bud nice one.
Whilst your here big g, what size fuel pipe would i need to fit over the fuel filter. is it 6mm/1/4 inch?
PostPosted: Sun Jun 09, 2013 10:15 pm
Drives: C2 VTS
Last time I needed a replace men t drive shaft bms did a trade in of your old one if in one piece. Can't remember the exact costs but I remember it costing me about £60 after trade in.
Copper grease is optional, so don't worry if you don't have any.
PostPosted: Sun Jun 09, 2013 10:19 pm
ahh yes so they can recondition it? That about halves the price of new jobbies so that could be an option. Cheers Percy.
Yes i read its either or. To stop squeaking yes but from what i read Mechanics do it but 'Brake Engineers' don't lol
PostPosted: Sun Jun 09, 2013 11:27 pm
Drives: C2 VTS
Yes that is basically the deal, I will say that was on my Saxo so prices may be different but its worth giving them a call and seeing what they offer if there is one nearby. I am sure others will offer something similar.
Well the reality is it won't stay there and will eventually be gone anyway, it is purely to reduced squeak so not important.
PostPosted: Mon Jun 10, 2013 8:08 pm
Drives: Fiesta ZS
You need to grease them up so they slide though, make sure you grind the rust off the caliper or you'll get uneven wear like I have.
PostPosted: Mon Jun 10, 2013 9:26 pm
calipers are all refurbed chris so no rust ;) but ill grease em up regardless
ill have a call round andy, cheers
PostPosted: Tue Jun 11, 2013 7:26 am
Drives: Fiesta 1.4 cvh
What brand of brake pad are you using?and does it have an anti squeal backing on it already?
PostPosted: Thu Jun 13, 2013 8:27 pm
i think it does actually... ferrodo
