It is currently Wed Feb 21, 2018 9:57 pm
 Post subject: Major headache
PostPosted: Sat Jun 01, 2013 2:17 pm
Right lads.
Was hoping it would be a bit more straight forward for me but as per it's not.
Wiring and a few other things so i'll post some pictures and write up what i need to know then see who can work their magic ;)
First off is this... i believe i didn't have one previously so just wondering if i need one now and what it is exactly?
Next is a plug that is on the fuel railing loom. No idea where it goes as there are no more terminals near to it.
Next is a bit that is connected up to the carbon cannister thing (solenoid or something like that)... There are two terminals in the back of the air inlet, which side will this connect up to and do i just block the other off (which i believe is for the egr)
Finally, the Wiring from the start motor to the alternator. I have lives from the battery going to the stater motor and then another live going from the starter motor which joins two seperate lives going to the alternator as per pic.
I have a blue cable (which connects to the loom near the gear box reverse light plug), but i am unsure as to where the other end connects up to. Im sure it is for the starter motor but on my 1.4si it connected to the alternator?
Any help will be highly appreciated. My brain is much atm whilst trying to figure out the wiring over on the fiestaguides bit.
Thanks
 Post subject: Re: Major headache
PostPosted: Sat Jun 01, 2013 2:27 pm
Probably should be in technical probs... my bad!
PostPosted: Sat Jun 01, 2013 7:47 pm
Drives: Mk1 FRS and FRST
Just moved it for you Ben :thumbsup:
PostPosted: Sat Jun 01, 2013 8:07 pm
Thanks Dave
