It is currently Sun Sep 23, 2018 12:01 am
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Apr 19, 2013 3:35 pm
Drives: Fiesta 1.4 cvh
Sounds like it could be the diff bearings starting to fail, check your gear box oil, also, what vibra technics mounts are you using? As that could be making it sound 100% worse than what it actually is
PostPosted: Fri Apr 19, 2013 10:15 pm
gearbox oil fine no leaks, had the vibrations for a fair few years, using fast road spec vibra technic mounts
PostPosted: Fri Apr 19, 2013 10:29 pm
fiestasiphil wrote:
hi guys ive been having steering wheel vibrations on my fiesta si for a few years now and cant find the problem :(
ive tried a number on steering racks
had the tracking done a number of times
2 brand new driveshafts
replaced 2 buckled wheels
new steering uj joint
new track rods
brand new manual steering column
new top mounts
brand new gaz coilovers
new tyres
area six rose jointed wishbones
(cars been converted to manual steering)
still cant find the problem :(
i bought the rs turbo box back in 2007 for 50quid and seems fine driving but anything over 80mph i 90% of the time get the vibrations through the steering wheel
really want to get it sorted so i can have the confidence to take the car on the track, the lsd diff seems to be fine, just struggling to find the cause
all i can surgest is;
1) wheel bearings and new flanges (not second hand flanges as the wear)
2) you currently (if the same wheels and set up as when i used to work on your car) havn't got the sight spiot rings so theres a gap between the middle of the wheel hub centre and flange centre.
3) you changed them wishbones yet? as there will i imagine be zibrations from them being stiff and wear.
4) the nut behind the wheel.
good job its a 70 limit and your ok at 70!
TEAM AUBERGINE
PostPosted: Fri Apr 19, 2013 10:46 pm
yeh just not ideal when id like to take it on a track, wishbones are fine no play, ive got proper ford alloys on my si so no spiot ring required, got new flanges and bearing pressed in it hubs ready to go on when i next get a chance
PostPosted: Tue Apr 23, 2013 11:27 pm
the wishbones might be that ridgid that your possibly feeling every single bump. that could possibly be all the vibrations. does it lurch to one side or anything?
the alloys you had on the back a couple years ago had a gap between the hub centre and wheel centre and i pointed this out to you. but tbf you prob have the right wheels now you changed them about so much.
TEAM AUBERGINE
PostPosted: Wed Apr 24, 2013 10:48 am
nothing to do with the wheels, i think what your saying is i was using universal rear wheel spacers, i now have hubcentric ones on the rear
PostPosted: Wed Apr 24, 2013 10:52 am
car drives in a straight line, had the wishbones on the car since 2007, not many miles have been covered in that time due it being off the road for 3/4 years of that, its got mot on friday and im getting the tracking done as one track rod ends thread stripped new hubs and new discs and pads are on, slight improvement but its still there
.. so replacing both track rod ends tonight
PostPosted: Wed Apr 24, 2013 10:59 am
The lower arms won't cause problems like that unless one of the bearings/bushes has failed, so unless you haven't checked them, you can rule that one out
PostPosted: Fri Apr 26, 2013 12:51 pm
new hubs fitted and new track rod ends, just had the tracking done and vibration still there
PostPosted: Fri Apr 26, 2013 12:52 pm
Have you checked that the carriers for the lower arms are tightened up good and proper?
Clutching at straws as its the only other moveable thing thats connected to the steering wheel that you ahvent changed that I can think of!!
Paul
PostPosted: Sat Apr 27, 2013 7:14 pm
Paul
i will double check those next week mate, passed mot yesterday third time in a row though :)
PostPosted: Sun Apr 28, 2013 7:55 am
Drives: Jap Crap
Say you're on your private road/track, when you go above 80 and the vibrations come, do they stay, gradually get worse the faster you go or start to tail off again at say, 95/100?
I would logically say it is something to do with the rotational system first, than suspension movement caused by the added force of speed and gravity. So make a list of everything involved in the rotation of the wheel and tick it off one by one.
If it's not unbalanced shafts, wheel bearings, wheel balancing or even sticky callipers then it's a toughie. Good luck man.
PostPosted: Mon Apr 29, 2013 8:34 am
Drives: Nissan Pulsar GTi-R
God damn Phil, that must be pissin you off something shocking by now. Gutted.
PostPosted: Tue Apr 30, 2013 3:45 pm
it sure is des :( it kinda puts me off wanting to track it but took it round some good tight country lanes a couple of days ago and handled like a train, its just the high speeds, i did have some real problems with the driveshafts back in september as i changed the long dshaft no problems, put the new shorter one on and had major vibrations around corners so put old short shaft back on and was exactly the same, so i got pissed off and took it to a garage they found the fault was that the snap ring fell out of the long shaft while fitting the shorter one, so thinking about it there was probably nothing wrong with the new short shaft but i still have the old short shaft on it, the new one was since sold to a mate and i have it back at as it too was buggered might dig my recipt out and get it changed for another as im sure most motor factor parts have a years warrenty
PostPosted: Tue Apr 30, 2013 4:02 pm
Drives: 08 Ford Focus 2.0
could be the old shaft then phil!
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Tue Apr 30, 2013 4:23 pm
yep last thing im going try...then going to give up lol, the old shaft has a new cv joint but could be the inner joint at fault, but i still think its the gearbox :rolleyes:
PostPosted: Tue Apr 30, 2013 4:29 pm
only one way to test the gearbox :doh:
PostPosted: Tue Apr 30, 2013 8:54 pm
Drives: Jap Crap
I can sympathise with you Phil. Had a very strong and loud vibration at 4000rpm for months and months. Finally found the exhaust itself to be causing the resonance and vibration, then all of a sudden a few days ago the resonance almost totally disappears. I've still got no real idea what it is exactly.
I nearly gave up and handed it to a garage to diagnose properly. Sometimes it's just easier to pay a little money and let someone who sees this kind of thing often taken a look, unless you've gone down that route already?
PostPosted: Tue Apr 30, 2013 10:10 pm
id love to take it to a garage to get it sorted only thing is that it happens at 80mph plus not sure how or who could test it :rolleyes:
PostPosted: Wed May 01, 2013 7:48 am
I wouldn't trust any garage, nobody knows my car better than me :lol:
Phil, if you're only getting a bit of vibration at much higher speeds, don't let that put you off taking it on track.
Out of interest, let's say you're at 80mph, in 5th, and the vibration is there, if you change down to 4th, is it still there?
Users browsing this forum: Bing [Bot] and 1 guest
