It is currently Fri Jul 20, 2018 7:43 pm
Post new topic Reply to topic  [ 64 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Oil Dipstick problem
PostPosted: Tue Apr 30, 2013 8:57 pm
Drives: Jap Crap
So I was kind of on the right track when I asked you if your sump was nice and clean on Sunday ;) The sump itself was clean, just not the plug at the back which is usually hard to see :lol:
PostPosted: Wed May 01, 2013 7:50 am
Drives: Nissan Pulsar GTi-R
Sump plug leak.
All this for a fekkin sump plug leak.... :lol: Jesus Adam, get your head under the car more often!! You own a unique car now, you better get used to getting your hands dirty! :D
PostPosted: Wed May 01, 2013 8:06 am
Drives: 08 Ford Focus 2.0
yeah i thought something was amiss as the sump is genuinely clean :lol:
jacked her up and got under there and voila :lol:
FACT wrote:
Ben Elvin "Jam" wrote:
PostPosted: Wed May 01, 2013 9:52 am
Drives: Sideways
This thread has made me die a little inside!
AUTOBAHNSTORMERS
PostPosted: Wed May 01, 2013 10:31 am
although i had this problem pre-oil change aswell
woodsy - for the 100th time - fuck off!
PostPosted: Wed May 01, 2013 11:58 am
I dont think a sump plug leak will be the cause of this in all honesty. I think as Danny has suggested, to measure the dipstick against a standard one will be a good start so you know what you've got. If it's been adjusted to take into account the increased oil requirements, going by a standard zetec fill amount will be wrong.
PostPosted: Wed May 01, 2013 1:05 pm
i measured the dipstick at just over 53cm so sent that to danny - awaiting a reply :)
PostPosted: Wed May 01, 2013 4:13 pm
I keep forgetting to measure :lol: I will try do it this afternoon :D
PostPosted: Wed May 01, 2013 4:40 pm
cheers mate :)
PostPosted: Thu May 02, 2013 7:44 am
Whip it out, wipe it, measure it, compare it, dip it ;)
PostPosted: Thu May 02, 2013 3:40 pm
Total length 56.5cm, or there abouts.
PostPosted: Thu May 02, 2013 3:41 pm
cheers danny
will double check but could swear it was just over 53cm when i measured mine......
could explain my issue
PostPosted: Thu May 02, 2013 3:56 pm
Drives: Fiesta ZS
I still stand by the issue is, you have a leak :
PostPosted: Thu May 02, 2013 4:03 pm
Drives: Sideways
Earlier, meilack wrote:
there was barely any oil on the dipstick - ie - it only covered 1/4 of it usually the whole dipstick has oil across it's whole width :lol: get me?
Not really
AUTOBAHNSTORMERS
PostPosted: Thu May 02, 2013 4:05 pm
Chris - i had this issue pre leak - there is no denying the leak is a problem and needs sorting
woodsy - i mean this nicely - but you are an annoying cunt :lol:
PostPosted: Thu May 02, 2013 4:21 pm
Drives: Sideways
:lol: I get you're saying, but my point was genuine, and still stands.
ps. there is a remote possibility the confusion stems from you initial shit description, just maybe :P
AUTOBAHNSTORMERS
PostPosted: Thu May 02, 2013 7:06 pm
Drives: Jap Crap
You, Sir, have a big penis.
I mean, good luck with checking your dip stick length.
PostPosted: Fri May 03, 2013 8:37 am
This thread is awesome :lol:
Adam - regardless of there being a leak, you should be getting consistent readings on the dipstick. I have an oil leak at the mo, but the oil just gradually drops, doesn't show up then disappear from the dipstick. The way you (somehow) describe the issue seems to be that it's random as to how much and when it shows up on the dipstick. If yours has been shortened, in order to allow for the extra oil needed for the turbo, then obviously the standard amount of oil isn't enough. Get it measured, then we'll know where you stand. Then you can drop the oil, fill it back up with the full amount required for a standard zetec and see if it shows up. If not, keep going until you then reach the desired level, keeping track of what extra you have to put in to get it to register :)
PostPosted: Fri May 03, 2013 12:34 pm
Des has riased a good point there.
It is assumed that you require more oil than a standard zetec as you now have oil lines etc for the turbo which need filling to function properly, and as such the standard dipstick marks for min and max are no longer appropriate for the quantity of oil you need.
This would tie in with you having a shortened dipstick to move the markings up inside the sump therefore showing minimum oil at a larger volume than standard. As such comparing to any other dipstick is pointless IMO.
What you need to know is what is the minimum amount of oil required for your engine and then check that your dipstick shows this volume at or near the minimum mark.
Remeber when checking oil that the first time you take the dipstick out means nothing as oil will have run down the dipstick during use/sitting and is why you wipe then measure so it sonds to me like you have no where near enough oil for what your engine needs (as long as the disptick has been calibrated correctly for the quantity of oil needed!).
Does the above make sense or are these the ramblings of a beechams fuelled mind fuck i'vejust created in my head?!?!?
Paul
PostPosted: Tue May 07, 2013 10:09 am
Agreed, although I don't think it's pointless comparing it to another dipstick, it will at least allow him to see if it has been shortened and then go on and refill up to what's needed :)
Have you measured yours yet Adam??
