It is currently Mon Jul 23, 2018 4:55 pm
 Post subject: front bottom arm
PostPosted: Sat Jan 05, 2013 3:25 pm
Drives: fiesta si
hi i am going to attempt to change the bottom arm onmy car i was wondering if its just the 2 bolts and ball joint to remove it.
 Post subject: Re: front bottom arm
PostPosted: Sat Jan 05, 2013 6:15 pm
Yup
PostPosted: Sat Jan 05, 2013 6:42 pm
Drives: Fiesta 1.4 cvh
You'll need 18mm spanner for both nuts on the top of the sub frame and 15mm socket and breaker bar to remove both bolts and a t50 torx socket and a 16 or 17mm socket to remove the ball joint pince bolt
Users browsing this forum: Google [Bot] and 9 guests
